oil sending unit
Old Jul 31, 2012 | 01:27 PM
24bing's Avatar
oil sending unit
ok olds guys, need some help. i have a 1969 442 with 400 motor. have factory electric gauges for oil and temp. my oil pressure needle will jump around for a bit then settle in to where it needs to be. does it quite often. i replaced the sending unit but still does it. any solutions?? if you would, PLEASE e-mail me direct at 24bing@charter.net. would appreciate any help!!
Old Sep 20, 2012 | 09:57 AM
Del70's Avatar
Did you find a fix for this issue?
Old Sep 26, 2012 | 07:22 PM
Rich Kinsley's Avatar
I wonder if the connector is corroded or loose for the sender wire? Is the oil pressure gauge the only one affected? I was wondering about voltage issues in the dash?
TheRuss
Sep 30, 2025 05:33 AM
bcg88
May 18, 2009 05:18 PM
oldsvair
Nov 16, 2008 03:10 PM
boese1978
Jan 22, 2008 11:56 AM
