Oil pressure Switch for Choke Wiring - question?
Old Apr 22, 2017 | 09:14 AM
1968_Post's Avatar
Okay, Question...
I purchased the BWD S369 switch and either I'm being stupid (which is always a possibility), or something is amok. First, I'm using aftermarket electric gauges and do not have an oil light on the dash, just the pressure gauge. According to instructions, I have the S369 switch installed with a tee fitting. I have attached a fused lead from the alternator post to one terminal on the switch and another lead from the 2nd terminal to the positive side of the choke. Since I have no oi warning light, the 3rd terminal is unused.
If I understand the operation, I should only have power out to the choke when the engine has oil pressure. However, I have power to the choke even when the key is in the off position. What am I doing wrong?
Old Apr 22, 2017 | 02:13 PM
1968_Post's Avatar
I added pics to show installation... wire to the left post is the power from the alternator, wire on the right is lead to the choke. Right lead is constant hot.
Old Apr 22, 2017 | 02:30 PM
VC455's Avatar
Barely Registered
The diagram doesn't seem to make sense.
To work correctly, it should get switched 12V, not constant hot. The diagram shows a constant hot.
If that were the case, and if you swapped the "to oil light" and "to choke" it could possibly work as you described.
Start the car and check if you have power to the choke. If you do not, then you could switch "to oil light" and "to choke" wires.
Then you would correct the 12V supply problem.
Otherwise, I can see why you are puzzled.
Old Apr 22, 2017 | 02:47 PM
What's the voltage reading on that terminal? Perhaps you used the wrong one?
Old Apr 22, 2017 | 04:11 PM
1968_Post's Avatar
13+ on both terminals... if I switch the leads, I get the same result. Voltage on the 3rd terminal is goose eggs no matter which other terminal I power...
Old Apr 22, 2017 | 04:17 PM
1968_Post's Avatar
My understanding is that the terminal shouldn't be hot until there's oil pressure at the switch. I'll try that, but all that I have seen shows using the opposed terminals for power and output. Have you seen the post the diagram came from? If not, take a look at it.
Thanks for the response.
Old Apr 22, 2017 | 06:04 PM
So you're saying the switch is not switching and you have a power splitter. Sounds like a faulty switch.
Old Apr 22, 2017 | 06:17 PM
1968_Post's Avatar
I'm gonna try a different brand of switch to either rule out the faulty switch or to fix my problem. I was searching for reassurance that I wired this the way it was first shown in Joe P's initial post. Electrical work isn't my forte so I'm always glad for guidance.
Old Apr 23, 2017 | 06:41 AM
RetroRanger's Avatar
72 Olds CS
Same thing happened to me, wired it up but never checked, two days later dead batt...hmm last thing I worked on was the choke so then I checked it, yup 12v to choke all the time, I bought another switch but haven't swapped it out yet. I'll see if I can find the two brands I got, IIRC I homed the second switch and it appeared correct, i.e. No continuity between 1 n 3 terminals w no pressure.
Edit:
First switch was standard ps127
Second switch was airtex 1s6552 this one is not tested as working yet, the ps127 was how you described yours.
Old Apr 23, 2017 | 07:22 AM
1968_Post's Avatar
Thanks Retro... That's exactly what happened to me! I had the car hooked up to the battery tender and noticed I was at 60% and charging. The last thing done was the choke, so I felt the housing and it was hot.
I've been doing a little research this AM and am going to try a different switch. Since I have no oil warning light any more, I don't need the 3rd terminal. I'm going to try a PS115, which shows to be a normally "open" 2 post design. I'll post results later today...
Old Apr 23, 2017 | 10:28 AM
The specs on the PS127 switch are the center terminal (designed to operate the OIL idiot light) is normally closed to case ground with no oil pressure and opens at 4-6 psi. The outer two terminals are normally open and are connected to each other (and nothing else) above 7 psi. The PS127 has been functioning in my 62 F-85 for about seven years now with no issues.
The BWD S369 is SUPPOSED to be an interchange for the Standard Motor Products PS127. I cannot vouch for the accuracy of that interchange; I only repeat what is listed in the catalogs.
It is VERY easy to test the functioning of the switch with an ohmmeter. Pull all the wires off the switch. With the engine off, you should read open circuit (infinite volts) from either of the two outboard terminals to any other terminal and also open circuit to ground. You should read zero ohms (closed circuit) from the center terminal to ground (the switch case) and open circuit to either of the outboard terminals.
Now start the engine. You should read zero ohms across the two outboard terminals and infinite ohms from either outboard terminal to ground or to the center terminal. You should also read infinite ohms from the center terminal to ground.
If these test are correct, the switch is functioning as intended. If not, it is either bad or mis-boxed. There are identical appearing switches that are wired differently and it wouldn't surprise me if they got put in the wrong boxes.
As for constant hot vs. switched hot as a 12V source, it doesn't matter. The switch is open with the engine off.
Old Apr 23, 2017 | 03:06 PM
RandyS's Avatar
It looks to me that your meter is set to DCV, not Ohms......?
Old Apr 23, 2017 | 05:23 PM
1968_Post's Avatar
You're right... I forgot to reset the meter when I took the pics. I already returned the switch so can't take another pic, sorry.
Old Apr 23, 2017 | 06:09 PM
Cincinnati Rick's Avatar
Slight correction. With the engine off you should read infinite ohms not volts.
Old Nov 23, 2019 | 02:02 PM
Phoenix8990's Avatar
Choke
Well I picked up the correct sending unit and all is well, dash light works, choke works. It is nice to get something completed. I also threw in a set of KYB shocks all the way around. I'm waiting on the rear sway bar. At that point having gone through the front and rear suspension and steering gear I will see how it is suppose to handle.
Thanks for the help,
Steve
Old Jun 22, 2020 | 06:58 PM
serta1's Avatar
Hello. Great thread. I have a 1971 Cutlass with 350 4bbl Rochester. I replaced the divorced choke with EC. The oil pressure switch has been replaced with an oil line running to the gauge under the dash. I would like to use the other method to connect the choke to but cannot find the relay with the 85, 86, and 87 connectors. Also there appears to be a vacuum hose behind the choke. What gets connected to that? Thank you.
Old Jun 23, 2020 | 05:24 AM
Any common 4 or 5 pin relay at the local parts stores are wired the same. Pin 85 and 86 are to the relay coil (some of the OEM relays have diodes across the coil pins to prevent voltage fly back so polarity is important) pin 30 is the common. Pin 87 is normally open across pin 30 and 87 with the relay off. Pin 30 and 87a will show continuity with the relay off. Turn on the relay, 30 and 87a will open, pin 30 and 87 will now have continuity.
watch this, a picture (or video) is worth a 1000 words
Old Jun 23, 2020 | 05:59 AM
There are a million of these in any auto parts store.
Old Jun 24, 2020 | 12:41 AM
serta1's Avatar
Thank you for the reply. I thought there was already one in the car installed for the alternator or did I misunderstand the original post from several years ago. So I will have to buy a 20 amp fuse, and blue and green wire. What is the gauge of the wire? Is there a standard color coding similar to house wire, ie 14 gauge is for 15 amp circuits, 12 gauge yellow is for 20 amp circuits?
Old Jun 24, 2020 | 05:14 AM
No, there is noting already installed unless you have a 1980s car that came from the factory with an electric choke.
Old Jun 24, 2020 | 01:15 PM
serta1's Avatar
I bought all the parts. Now to implement it and see if the car will start.
Old Jul 18, 2020 | 03:56 PM
serta1's Avatar
Thank you for the video. I notice in the video the ground is number 85 where in the diagram 86 is the ground, 85 and 86 are reversed. Does this matter which one is the ground and which one goes to switched power?
Old Jul 20, 2020 | 10:41 AM
serta1's Avatar
Electric Choke Update
Here is the latest update. I found where the Oil Pressure switch was located thanks to this thread. The original switch was there but the wire had been cut since the car now has the Oil Pressure Gauge instead of the light. I purchased the PS127 switch and installed it.
Old Jul 20, 2020 | 10:54 AM
serta1's Avatar
I wired the choke up per the diagram. With the car not running I get 13 volts at the terminal going to the alternator. The other side going to the choke is zero volts. When I try to start the car it fires for about 5 seconds then stops. Is there something else that I am missing? I attached some photos of the carburetor I purchased a couple of years ago. Did I miss anything? A new fuel pump was installed at the time. There was a rubber hose from the pump to the old carb. I purchased the metal line as you can see in the photo plus I replaced the linkage since the one on the car was some kind weird setup. Also, new fuel tank float, etc, and lines running to the vape box behind the rear seat. Is there something missing from the rear of the choke? Thank you.
Old Jul 20, 2020 | 04:44 PM
72 Olds CS
the threaded part at the rear of the choke is for a hot air choke. Your carb now has an electric choke.
Old Jul 21, 2020 | 05:25 PM
serta1's Avatar
Retro Ranger,
Thank you for the information. I presume that means I do not have to do anything with it.
Old Jul 21, 2020 | 05:28 PM
72 Olds CS
Retro Ranger,
eh maybe.
I just capped mine off to keep any debris out of it. I also capped off the ports on the back of the carb. The cavity on the intake manifold just below your choke can be blocked off too just for aesthetics
Old Jul 21, 2020 | 05:38 PM
serta1's Avatar
I will look for some plastic caps for the choke. I think I have some in my box of AC parts. Thank you again.
joe_padavano
Tech Editor's Desk
98
Nov 14, 2025 01:59 PM
ralsy
Dec 7, 2013 02:51 PM
Al Sanchez
Mar 5, 2013 04:49 PM
bobfo1
Nov 25, 2012 10:37 PM
76Supreme350
May 16, 2011 05:41 PM
