NO TURN SIGNAL
Old May 12, 2008 | 08:20 PM
Theo's '67's Avatar
NO TURN SIGNAL
I have a 67 delta vert....my hazards work fine but my turn signals do not work. Any help anyone can provide would be great.
Old May 12, 2008 | 08:24 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I think I have seen that 67 before!
I was up there visiting a friend at Carrol.
Old May 13, 2008 | 05:22 AM
ozoneblue's Avatar
try swapping the T/S flasher & the hazard
Old May 13, 2008 | 09:25 AM
They are probably different. Just get a new flasher. They are not expensive and it's easy to change. If the system still doesn't work, start chasing the circuit, starting with power to the switch.
Old May 13, 2008 | 08:46 PM
Theo's '67's Avatar
You probably did. I live right by Carrol College.
Old May 13, 2008 | 08:51 PM
Theo's '67's Avatar
I was thinking that but I cant find a fuse for the turn signal by itself...So then i thought maybe the the actual turn signal in the steering column was bad and was going to replace that.
Is there a place I can go to get the wiring diagram for my 67.
Old May 14, 2008 | 05:12 AM
Oldsguy's Avatar
Past Administrator
The turn signals aren't fused seperately to my knowledge. Did a new flasher unit work?
Old May 14, 2008 | 03:59 PM
Theo's '67's Avatar
No it did not work.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
allthumbs
Jan 8, 2007 02:24 PM
js_specials
Aug 18, 2006 10:31 AM
