No tail lights or dash lights
I have a 1985 Cutlass Supreme and the tail lights not dash lights work. I have checked the bulbs and fuses and they are all good. The brake light and turn signal lights work. Any help or even point me in the right directions as I am green to this.
I moved your thread to the Electrical forum, post an intro in the Newbie section when you get a chance. Have you checked your tail light fuse? Were you doing any work previous to the lights quitting?
Did check the fuses and I didn’t do any work and the mechanic that was working on it I don’t believe did anything to it. He brought it to my attention when I picked up from him. Thank you for the transfer.
I had this problem on a 70 442. My rear bumper grounds needed cleaned up. Old timer mechanic told me thats how you could tell if all your tail lights are out, Sure enough I cleaned grounds and all worked. I had tested all the lights prior to installing the bumper assy and all worked great. Hope this helps.
