no tail lights
no tail lights
On my 1983 buick park avenue I finished up my interior lighting problem and I thought everything was fine until at night I seen I had no taillights is there anything I could have unplugged inside the dash? Fuse is good
Do the rear side markers or lic plate lights work? Those should be on the same circuit and will point to the location of the trouble. If those do not work the problem may be in the connector from the rear body harness somewhere under the dash.
If the dash lights aren't working, since they're with the tailights, it's gotta be the circuit!
If the taillights aren't working themseves, it's the wires!
There shoud be a GROUND wire, usually black, somewhere around the L/R wheelhouse, in the trunk.
Make sure that's connected,and it's grounded to bare metal.
If that doesnt do it, trace the wires from the back to front, looking for damage - should be on the drivers side, all the way up.
Oldssupreme
Apr 3, 2015 08:36 PM
