No heat
Old Nov 25, 2007 | 06:57 PM
GOOSE_92's Avatar
No heat
I drove my 71 cutlass today on the road for the first time since I baught it, I was wondering what is wrong with it since it is not blowing any hot air. The Fan motor is not working and when it is at running temp there is nothing. Is this a heater controll or a fan problem?
Old Nov 25, 2007 | 07:06 PM
kevinkpk's Avatar
Can you feel hot/warm air from the center bottom air duct, if you have heat selected or defrost, you should feel warm/hot air even without a fan. If you can it isn't anything other than the blower motor (or so). The fan motor should blow anytime you select it to on.
Old Nov 25, 2007 | 08:42 PM
GOOSE_92's Avatar
I got nothing on defrost or heat not even cold air.
Old Nov 26, 2007 | 05:03 AM
kevinkpk's Avatar
You should have an air inlet door in the plenum, mine is vacuum operated, yours is or open closed by a cable. take a look at that.
Old Nov 26, 2007 | 05:55 AM
Jokers69's Avatar
Senior Moment
No fan at all, check the fuses
Dream Whip
Aug 9, 2016 02:59 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
<sammy>
Sep 1, 2006 05:04 AM
Bens71442
Jan 3, 2006 03:33 PM
