No Gauges - Looking for possible remedies
Old Mar 29, 2011 | 09:20 AM
71KUTLASS's Avatar
Ok, my 72 cutlass gauges are not working. I have no speedometer no fuel, but I do get the red square in the instrument panel when i turn the key to acc. I have replaced all fuses. NO WIPERS EITHER.... Im heading to the garage now to pull out the cluster and test for power. Any suggestions would help. Thanks
Old Mar 29, 2011 | 09:46 AM
72 cutlass455's Avatar
Check for broken ground or bad ground.
Old Mar 29, 2011 | 10:41 AM
jaunty75's Avatar
Certainly the speedometer is not affected by anything electrical. That's strictly a mechanical connection. If your speedometer needle doesn't move when the car does, you need to check the cable. It runs from the back of the cluster to, I believe, the left front wheel.
Old Mar 29, 2011 | 11:39 AM
Bluevista's Avatar
Registered
x2 on the grounds, check the engine to firewall.
Weird that the speedometer isn't working?
Maybe the engine to body ground came loose and it grounded through the speedometer cable and messed it up? I've seen that happen with shifter cables, melts the plastic casing to a crisp.
Old Mar 29, 2011 | 12:59 PM
71KUTLASS's Avatar
Thanks I got it all pulled apart and man its a mess behind here.
odddoylerules
Mar 8, 2015 07:49 PM
72olds442
May 5, 2012 04:53 PM
citcapp
Dec 14, 2009 11:10 AM
OldsMotion
Drivetrain/Differentials
Apr 17, 2007 05:39 PM
Redog
Feb 23, 2007 06:05 AM
