New Stereo for '84 Olds 98 Regency Brougham
Old Jul 23, 2007 | 07:24 PM
kyleg's Avatar
Question New Stereo for '84 Olds 98 Regency Brougham
Hi All,
I recently purchased an '84 98 Regency with a Delco ETR AM/FM Cassette deck, and I'd like to swap this out for a new stereo. I've done lots of searching and the most I've been able to learn is how to remove the front panel and that I probably need a 1.5 DIN size stereo - can anyone verify that? I'd like to do the installation myself, and don't want to have to cut or modify the existing panel. Can it be done, especially without spending an arm and a leg?
Cheers,
Kyle
Old Jul 24, 2007 | 04:32 AM
ozoneblue's Avatar
Wink Stereo Instalation
Check with Radio Shack they sell a assortment of faceplates & mounting hardware Also get the new plug from them so you dont have to cut the factory harness
Old Jul 25, 2007 | 08:28 PM
kyleg's Avatar
Thanks for the advice, ozoneblue, I'll check them out. Thing is, there's no way the opening in the current panel is wide enough for a CD, which has me worried. I'll wait to see what the say, unless anyone out there has dealt with the same issue.
Cheers,
Kyle
Old Jul 27, 2007 | 01:43 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Post
I notched my dash out on my 85 delta, no big deal. They made so many of those you could find another dash if you ever wanted to convert back. Once you have your new bada$$ stereo in you won't even care about the dash anymore anyway. Bluebook value on an 84 regency is probably 700 bucks if you had every option and 30000 miles on her. My insurance company wanted to total my car out for 6 or 700 hundred bucks a few years ago after someone backed into my door at Best Buy. It only had 70000 on it so I obviously told them to get bent and just put another door on from the boneyard. My neighbor just recently backed into THAT door and I can't say I'm thrilled. Anyway, If I remember correctly on my dash the volume and am/fm selector **** along with the R/L balance rings, pulled right off. There were 2 screws above the cigarette lighter and the faux wood panel pulled right off of a few clips. Worst case scenario you break it and can only find a panel without the rear defog cutout and have to move the switch elseware. 99.99% unlikely though.
--J
Here is some info from Mike Jones.
1980
Model Units
Delta 88
2 door 6,845
4 door 15,285
Royale 2 door 39,303
Royale 4 door 87,178
Delta 88 Royale Brougham 2 and 4 door are included in 88 Royale totals.
98
Luxury 4 door 2,640
Regency 2 door 12,391
Regency 4 door 58,603
1981
Model Units
Delta 88
2 door 3,330
4 door 10,806
Royale 2 door 41,682
Royale 4 door 104,124
98
Luxury 1,957
Regency 2 door 13,696
Regency 4 door 74,017
1982
Model Units
Delta 88
4 door 8,278
Royale 2 door 41,382
Royale 4 door 105,184
98
Regency 2 door 11,832
Regency 4 door 79,135
Regency Brougham 4 door is included in basic sedan total.
1983
Model Units
Delta 88
4 door 8,297
Royale 2 door 54,771
Royale 4 door 132,683
98
Regency 2 door 13,816
Regency 4 door 105,948
98 regency Brougham 4 door is inculded in basic sedan total.
1984
Model Units
Delta 88
Royale 2 door 23,387
Royale 4 door 87,993
Royale Brougham 2 door 41,913
Royale Brougham 4 door 89,450
Royale Brougham LS 4 door 17,064
98
Regency 2 door 7,855
Regency 4 door 26,919
Regency Brougham 4 door 43,059
This was the last year of the RWD-C body chassis.
Old Feb 9, 2010 | 07:22 PM
Fitzgerald's Avatar
i have the same car. i had to cut the dash where the old stereo was either that or you need to mount it under the ash tray. One problem i ran into though is that the power antenna doesn't go up and down now. I think I need to change my wiring a bit. I can post some pictures if you would like but you are just going to have to find the stereo you want and make your cuts precisley. Behind the plastic dash there is a steel mounting bracket that you attatch the new stereo mount to. you need to make sure that your mounting on the steel bracket lines up with the plastic dash cutout for the stereo. hope it helps if anyone knows how to get the antenna to work i would appreciate it.
heres why my antenna is broken and just runs and runs
https://classicoldsmobile.com/forums...schematic.html
Last edited by Fitzgerald; Feb 9, 2010 at 07:30 PM. Reason: found answer in another post
Old Feb 10, 2010 | 04:40 AM
rocketraider's Avatar
Oldsdruid
If that ETR unit works and looks good, lemme know if you want to sell it.
Yah, I'm one of them dinosaurs who still has cassettes and vinyl. The stuff works, some of it is impossible to replace on CD, and I'm comfortable with it.
You MIGHT be able to get a faceplate from an 86-90 Custom Cruiser. Think they have a large opening that you can use an installation kit with. Can't guarantee the woodgrain will match the 84 though. A wiring harness adapter is easily found. Scosche and Metra both make them.
Old Feb 10, 2010 | 04:55 AM
Bluevista's Avatar
Registered
Juast go to Crutchfield.com and they have the stereos, illustrated instructions, installation kits, and they'll walk you through any aspect over the phone.
You can plug in your model of car on the site and it will bring up everything that fits it too.
http://www.crutchfield.com/
Old Feb 10, 2010 | 07:23 AM
The Delta is designed for a twin-shaft radio. Good luck finding an aftermarket one of those these days. If you remove the plastic dash panel, you'll see that the radio is retained with a metal plate that bolts to the dash carrier. You can cut this metal plate to support the new radio and then trim the front panel to match. Be sure to reinstall the rear support on the radio or you'll eventually crack the plastic dash carrier.
If all you want is a CD, consider a remote changer like I have in mine. It plugs into the antenna feed on the stock radio and has a remote control that you can mount anywhere. No cutting required.
Machwest
Aug 14, 2014 05:32 AM
Machwest
Jan 21, 2014 07:01 PM
techcote
Dec 25, 2012 08:53 AM
Varmit
Ninety-Eight
Sep 23, 2008 07:17 PM
