need to replace alternator
Old Apr 20, 2022 | 06:05 PM
prlynch01's Avatar
Can someone recommend a quality replacement alternator for my 1970 442? Y72 (HD cooling), (G91) 3.32 gears and C60 (AC). Originally came with 1100890 55A. Found a date coded reman for $1500. Really? I don't think originality is that important!
Old Apr 20, 2022 | 06:36 PM
bccan's Avatar
Do you have the original? I’m guessing no but if you do, get it rebuilt/restored.
Decisions are easier when you drive a mutt!
Old Apr 20, 2022 | 06:49 PM
prlynch01's Avatar
I do not have the original or I definitly would have that restored. It currently has a no name aftermarket alternator that took a dump.
Old Apr 20, 2022 | 06:57 PM
I discovered that a local armature shop would rebuild my alternator, replacing just that parts that were needed, and it was cheaper than buying a rebuilt unit from the auto parts store. If the alternator required a complete rebuild, they did it for the same price as the parts store remanufactured unit, so it was a no-brainer to bring it to them.
Old Apr 20, 2022 | 07:25 PM
70sgeek's Avatar
'72 Cutlass ragtop
If an actual OEM replacement not a requirement for you, Bosch and Powermaster both make all brand-new direct-fit internally regulated replacements - Bosch is 62 amp and Powermaster = 100amp. I have the Powermaster and it's been rock solid since install about 2 years back.
Either alternator will allow you to eliminate the firewall mounted voltage regulator by performing a simple engine harness wiring bypass for the connector that plugs into it.
Old Apr 20, 2022 | 07:41 PM
prlynch01's Avatar
Any suggestions if I decide to keep the external regulator? Does AC Delco make a new alternator with an external regulator?
Old Apr 20, 2022 | 09:29 PM
stellar's Avatar
stellar
1100890 is an internal regulator.
OLDsBARRY
Oct 20, 2021 02:34 PM
68442
May 24, 2016 07:30 AM
capstoneclub
May 4, 2013 08:39 PM
my442conv
Sep 15, 2011 09:39 AM
my442conv
Sep 15, 2011 07:55 AM
