Mystery battery drain
Old Aug 10, 2014 | 03:41 PM
hurstman1972's Avatar
I have a '72 H/O with a bone stock 455, that just started killing the battery after sitting overnight. The battery has been tested good, so I went thru various points on the wiring harness with an ammeter and found there is a 2.5A drain on the battery that disappears when I unplug the blu/wht connector from the alternator. It has a 63amp unit with an internal rectifier.
Any suggestions as to a next best step? I want to keep the original alt for authenticity's sake of course! Thx for any advice!
Old Aug 10, 2014 | 04:14 PM
Jetstarjim's Avatar
I had a similar problem with a Nova, and replaced the diode trio. It solved the problem in that case, but I have no idea why, lol!
Old Aug 10, 2014 | 05:23 PM
RandyS's Avatar
Me thinks that it is time for a rebuild on the Alt.
Old Aug 10, 2014 | 05:40 PM
Yes, a shorted diode will cause a continuous drain on the battery.
Old Aug 10, 2014 | 06:00 PM
66luvr's Avatar
Speaking from experience, most battery drains come from the regulator or the alternator. My local Advance and AutoZone can test both free. I normally remove both and test.
ctrain22
Sep 3, 2014 05:58 PM
olds88royalvert
Apr 27, 2014 08:42 AM
Dru
Feb 7, 2011 04:08 PM
pacho442
May 16, 2010 02:05 PM
a6m5zerosen
Jan 11, 2008 08:29 PM
