Is My Gas Tank Empty or Full?
Old Apr 14, 2009 | 03:34 PM
Deputy442's Avatar
Deputy Sheriff
My gas gauge is not working properly.
(1972 Cutlass Convertible)
I took it out of the dash, to check it (because its much easier to check it there, than to check the sending unit) The gauge seems to be working somewhat, but no matter where I move the needle to, as soon as I connect it again, it moves way past the full mark, to about the three o-clock position.
Does anyone have any ideas on what is causing this? I am afraid that it might be the sending unit in the gas tank, but I have no idea how to get to it to check it, or repair it.
Thanks in advance for your help.
PS: does anyone know how to spell Gage? Guage? Gauge? Gayge? Gaige?
Old Apr 14, 2009 | 03:55 PM
lshlsh2's Avatar
71 cutlass convertible
When I dropped my gas tank, I did not hook up the ground. I had the same thing happen. Check the ground connection. If it looks good take off and clean anyway.
Larry
Old Apr 14, 2009 | 07:42 PM
hamm36's Avatar
test fuel gage
https://classicoldsmobile.com/forums...fuel-guge.html
Read this and it will tell you how to check it. And how I fixed the other problem I had.
Olds442toro
May 31, 2014 07:25 PM
Dan Wirth
Jan 16, 2013 09:03 AM
at3reg98
Apr 17, 2012 10:36 AM
69CutlassSConvt
Dec 18, 2008 04:02 PM
