Megatronix Hood lock and ignition coil kill , what resistor
Old Apr 22, 2022 | 05:47 PM
Mac1911's Avatar
Have a 72 olds in the shop the owner really wants to old keyed cable hood lock ignition kill re installed.
Only thing left is the wire from the lock , the inline fuse ( how many amps ) and resistor are long gone. I do not know what belonged in there. Long before my time when they where installing these.
i would consider a remote key fob ignition kill also if there is a simple kit out there.
thank you
The switch still works
Not sure if indicator still works?
Old Apr 22, 2022 | 06:27 PM
Google is your friend. It looks like an ignition ballast resistor. It appears that all this system does is ground the negative side of the coil. The exact resistance value is not critical.
http://www.megatronixusa.com/manuals/HLManual.pdf
Old Apr 22, 2022 | 08:36 PM
Mac1911's Avatar
i found that , its lacking the fuse size and resistor spec.
Old Apr 22, 2022 | 09:32 PM
Select a resistor value that makes you happy, then calculate the fuse rating per Ohm's Law: I = V / R
Old Apr 23, 2022 | 03:50 AM
Again, this is not a critical value. All this system does is ground the negative side of the coil. The drawing shows a resistor the looks like a comment aftermarket ignition ballast resistor. I've done a similar kill switch with just wire. Something under 35 ohms is fine. I can't even see what the fuse does. That's a ground circuit.
Old Apr 27, 2022 | 08:20 AM
Mac1911's Avatar
Interesting so why does it have a fuse?
Old Apr 27, 2022 | 10:48 AM
"...out of an abundance of caution..."
I mean, seriously, that's the ground side of the circuit. Apparently this lock was not designed by rocket scientists.
Old Apr 27, 2022 | 05:26 PM
Mac1911's Avatar
im curious also since electrical science is not my thing why the resistor if its simply grounding the circuit?
Old Apr 28, 2022 | 04:57 AM
You'll have to ask the people who developed that kit. It appears from the instructions that their system is designed to be used across a multitude of different factory ignition systems, including electronic ones. The resistor won't hurt a point-type ignition system and is likely needed for the other applications. That lets them inventory and sell a single kit instead of multiple different part numbers.
Old Apr 28, 2022 | 04:51 PM
Mac1911's Avatar
makes sense.
oldolds88
Dec 9, 2021 07:49 PM
smparr
Nov 15, 2021 06:57 AM
slantflat
Mar 23, 2021 10:33 PM
67Rocket
Oct 18, 2019 03:21 PM
kdub
Apr 10, 2016 06:50 AM
