Maxi fuse terminals?
Old May 29, 2020 | 06:53 PM
I’m looking for some 8 gauge maxi fuse terminals for a fuse/relay panel I removed from a late 90s-2000 Blazer. I have one terminal in my possession, so I know they are available. I have tried Del City, Electrical Depot, and Waytek, with no luck. I plan to use a 80 amp maxi fuse which should be plenty of capacity.
Anyone in readerland know what the original function/application of this fuse/relay panel? It was mounted below/behind the passenger headlight of a 90s-2000 Blazer
I’m using the relay for the electric fuel pump. The maxi fuse will be a master fuse I pull to cut power to the car. The mini fuse will be wired to supply power to the clocks independent of the maxi fuse.
Old May 29, 2020 | 07:51 PM
Any marine supply store should have one. I would think it would be available at your auto parts store also. Any 8ga wire socket will work for 80a.
77ricbaez
Jun 29, 2017 01:16 PM
59Rocket
Jun 15, 2016 04:36 AM
mmurphy77
Jun 17, 2014 12:49 PM
sfh074
Sep 28, 2013 07:52 PM
72Cutlass_Sunfire_Yellow
May 21, 2013 06:31 AM
