Low beam/High beam
Old Sep 26, 2022 | 01:33 AM
kbdecatur's Avatar
Low beam/High beam
I have a1970 olds cutlass and I added LED headlights. When I press the switch for the high beams to come on the low beam goes out. This happens just on the drivers side. Any help would be greatly appreciated.
Old Sep 26, 2022 | 04:18 AM
JohnnyBs68S's Avatar
It sounds like the high-beam LED circuit on your driver's side outer (low beam) bulb isn't working. Try swapping low-beam bulbs. If the problem moves w/ the bulbs, you have a bad bulb. If the problem remains on the driver's side, look for some bad wiring on the high-beam circuit and/or connector. Check the grounds too.
Old Sep 26, 2022 | 05:24 AM
kbdecatur's Avatar
Zabbs22
Sep 28, 2022 07:41 PM
woodie582
May 18, 2021 09:23 AM
woody30
Tech Editor's Desk
Sep 15, 2012 08:45 AM
tpawlik
Sep 3, 2010 09:10 AM
BaileyJD1
May 1, 2008 11:45 AM
