Lost 12v at IGN spade on fuse block
Old Jul 29, 2014 | 10:57 AM
Cman7713's Avatar
Hey guys,
So had my 69 cutlass out last night for a drive. I was backing in to the driveway and the car died suddenly. My first thought was no spark from how it just instantly died. I checked the 12v wire to the HEI from the IGN spade on the fuse block, good continuity but no voltage at all with the key forward in the ignition. in an attempt to get the car back into the garage i jammed the 12v wire to the hei into the hot side of one of the fuses in the block and it fired up fine. Backed into the garage and pulled the wire out of the fuseblock to kill the car. Where does the IGN spade on a 69 Cutlass get it's switched power from and has anyone run into this issue before of losing power to that IGN spade while previously working fine?
Old Jul 29, 2014 | 11:13 AM
Check the adjacent fuses next to the IGN terminal, I think it may be powered off the turn signal fuse.
Oldscutty72
Dec 28, 2015 01:56 PM
455cutlass1969
Apr 19, 2014 04:21 PM
runnin350
Feb 2, 2014 06:37 AM
mont1le
Feb 14, 2010 07:24 PM
Dapapadon
Feb 27, 2008 08:10 PM
