lights pulse
Old Jun 15, 2012 | 01:42 PM
rmoths's Avatar
lights pulse
I have a 1972 cutlass and I noticed my interior lights would pulse when I rev the engine. I had the car out the other night and all the lights, Dash and head lights did this. Lights seem to dim a idle also.
I assumed the voltage regulator or alternator is bad, but I'm not sure if I have a alternator with the regulator in it or if the regulator is what I'm seeing on the firewall. What I see on the firewall sure looks like the regulator, but I've been told the alternator has the regulator in it. I know this is a dump question, but can it be either way. Thanks Barb.
Old Jun 15, 2012 | 02:20 PM
From the factory your car came with an external regulator mounted on the firewall. It should have a four wire connector with brown, white, red, and blue wires. The pulsing could be the regulator, alternator brushes, or a bad ground or missing ground strap.
Old Jun 15, 2012 | 03:54 PM
Lady72nRob71's Avatar
My lights pulsed like that when the external mechanical regulator was used. It stopped when i switched the mechanical reg to an electronic one.
Old Jun 15, 2012 | 06:21 PM
BILL DEMMER's Avatar
Just the facts...
there is an adjustment that can be performed to reduce/eliminate the pulsing.
it involves the thumb screw inside the regulator. myself, i went 12si, then cs130 and never looked back.
bill
Old Jun 15, 2012 | 06:31 PM
bill
I agree, the later alternators are well worth the trouble to install. Not that its much trouble to install one.
Old Jun 16, 2012 | 06:03 AM
rmoths's Avatar
Wink
OK! Thanks, As long as I'm not damaging anything running it this way. I'll take it in to my local shop, this looks like more than I can handle.
Thanks again guys, best source for information is you. Barb.
oldspackrat
Jul 19, 2016 01:48 PM
oldspackrat
Mar 12, 2015 06:34 PM
wizard
Nov 22, 2012 06:13 AM
Sid
Sep 10, 2010 02:33 AM
2blu442
Jul 22, 2008 03:49 PM
