lights flickering... on to the next problem...
Old Aug 7, 2014 | 07:34 PM
dom992's Avatar
Hi all! You guys are so much help so I figured I'd ask. But I got a new battery, new voltage regulator and also got the gen rebuilt and my gen light went away finally and she's charging fine now! Anyways on the next or problem.. I test drove it today and noticed my lights were flickering a little and it was making an awful belt squeak noise... other things I noticed is my instrument cluster lights come on when they want to, and don't work sometimes, my gas Gauge doesn't work, and my horn goes on and off also. And what I mean with all that is one time the stuff works while I'm driving and another time it doesn't. It sounds like a gen problem right?.. it's changing fine just would like some input. Thanks in advance!!!!
Old Aug 7, 2014 | 08:22 PM
illumined's Avatar
1978 Ninety Eight
Intermittent electronics in general is often either a short or a loose connection somewhere. The belt squeak might be unrelated.
EDIT: Now that I think about it I'm convinced the problem is a short, which would explain why the horn comes on by itself. The flickering of the instrument lights would be the power drain caused by said short.
Last edited by illumined; Aug 7, 2014 at 08:37 PM. Reason: Added some extra thoughts.
brown7373
Jun 4, 2015 01:09 PM
Jonmueller1
Feb 10, 2015 06:07 AM
BStone
Aug 2, 2012 07:56 AM
Sid
Sep 10, 2010 02:33 AM
VikingBlue
Aug 12, 2010 06:09 AM
