Lights Flickering
Old April 7th, 2018, 09:43 AM
johnspd22's Avatar
Lights Flickering
I had my 72 Supreme out today to get my annual inspection and noticed with the blower on high, the interior lights were flickering (I could also hear the load on the alternator varying quite a bit).
My guesses are -
a. External voltage regulator might be a bit sticky (car has been sitting at bit).
b. High Blower relay is not so good. I replaced this a while back with a 'Standard' brand replacement part.
Just wondering if someone had experience with this and any suggestions. Off high blower, the symptom seemed a bit less.
Thanks!
johnspd22 is offline
Old April 7th, 2018, 10:30 AM
Sugar Bear's Avatar
#1...voltage regulator. Clean and tighten all grounds you can find, especially at the firewall and/or fender, but still guessing regulator.
Good luck!!!
Sugar Bear is offline
Old April 7th, 2018, 01:58 PM
Definitely check the regulator, alternator brushes, and belt tension. I'll also add that I chased exactly this problem on a 68 Vista years ago. The cause in that case was corrosion on the wire from the alternator at the stud on the horn relay. Once I cleaned all those terminals, all was fine.
joe_padavano is offline
Old April 7th, 2018, 03:36 PM
johnspd22's Avatar
Good suggestions. I'm on it. Thank you.
brown7373
June 4th, 2015 01:09 PM
Jonmueller1
February 10th, 2015 06:07 AM
dom992
August 7th, 2014 08:22 PM
oldstuff
September 13th, 2011 08:03 AM
Sid
September 10th, 2010 02:33 AM
Quick Reply: Lights Flickering
