light issue
Old Sep 4, 2011 | 08:43 AM
Firstcutlass's Avatar
light issue
Ok my lights on low beam work great, the flashes work and dash stays lit. However on high beam the lights work the flashes work but the dash goes black.
What is happening? I'm lost. I replaced the dimmer switch already nothing changed. Please help.
Old Sep 4, 2011 | 08:54 AM
svnt442's Avatar
Sounds like you have some wiring to chase under the dash.
Old Sep 4, 2011 | 09:32 AM
This shouldn't happen.
My best guess is that some previous owner connected the instrument lamps to the low beam circuit instead of the instrument circuit.
Do the instrument lights din with the dimmer?
Old Sep 4, 2011 | 05:05 PM
Yes on low beam when they are on I can dim them. I noticed when I am on high the signal lights are on solid while everything else is blacked out and if I try to signal it is back wards. Right links the left light and visa versa. My problems are only in high beam.
Old Sep 4, 2011 | 05:23 PM
66ninetyeightls's Avatar
Land Yacht Captain
That is wierd.
Old Sep 5, 2011 | 05:41 AM
rustyroger's Avatar
'87 Delta 88 Royale
Take a good look at the grounds, bad grounds can give the wierdest of symptoms, including those you have.
It may well be you have another problem, but always check for good grounding first.
Roger.
Old Sep 16, 2011 | 05:26 PM
Ok after a few weeks, some good advice, and tracing a schematic I figured it out. The damn gauge was not grounded. All the wires were great but i noticed that the other gauges had a metal bracket where the mounting screws go. Speedometer didn't. I also remembered that when I pulled the gauge a paper clip fell out. They had ghetto rigged it. All it took was a 6 inch piece of wire. Simple damn fix. lol
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
mike623
Mar 26, 2010 08:32 PM
dan68toro
Aug 12, 2008 11:27 AM
