License Plate bulb socket
Old May 24, 2017 | 05:05 PM
gkhashem's Avatar
The socket cannot be fixed a ground issue. The bulb is 97 or 1155
Where can I get a socket I am not to bright I guess. Many sites have a push in bulb socket. This should be a push in and twist bulb.
I thought this would be simple to find
Old May 24, 2017 | 05:25 PM
It would help if you said what vehicle you are working on.
Old May 24, 2017 | 05:46 PM
gkhashem's Avatar
Sorry 1964 Olds 98, but the bulb is #97. Should not the socket be the same for that bulb?
Old May 25, 2017 | 07:59 AM
The socket is swaged into the housing. You won't find a specific replacement because it is not replaceable by itself. You will either need to machine out the old socket and adapt something else, find a good license plate light assembly, or do what I did on my 62 Olds and just replace the whole thing with an LED license plate light.
Old May 25, 2017 | 08:37 AM
rcorrigan5's Avatar
Randy C.
Would this work for your application? It's out of a '68. The bulb in it is a "67".
Randy C.
Old May 25, 2017 | 03:05 PM
gkhashem's Avatar
I got it working for now a temp fix. I am going to put a better ground on it and it should be OK. You're correct its the whole assembly.
Old Jun 10, 2017 | 04:06 PM
gkhashem's Avatar
Fixed the assembly had a guy solder a new ground on it and it's fine now.
JpMotorsports
May 24, 2017 05:52 PM
timholliday
May 13, 2016 04:53 PM
therobski
Aug 22, 2015 05:14 AM
68442S
Apr 10, 2014 07:20 AM
