Junction box
Old Aug 21, 2014 | 09:15 AM
ostie13's Avatar
Talking Junction box
I am installing a Tachometer in my 71 Toronado and when I was under the dash trying to find a place to attach the power wire I noticed that to the left of the fuse block,just in front of the E-brake was a place that had 8 metal prongs that you could attach wires to. Only one was pluged into it and the wire is red. To me it looks like a junction box.Can I plug my tachometer into it or am I way off base. I dont see anything in the 71 service Manual that showes anything about it but I am sure it is stock and not a
Old Aug 21, 2014 | 10:13 AM
RandyS's Avatar
You will want to check that this is a switched power location (has power when key is in run position). If it is, you can use it, if not, you will drain your battery.
Old Aug 21, 2014 | 10:26 AM
One row of those terminals is hot all the time (not good for the tach), and the other row is switched with the ignition.
Old Aug 21, 2014 | 01:21 PM
ostie13's Avatar
Should I put a fuse on the power wire and If so what size? Or does the junction block alredy have a fuse.?
Old Aug 21, 2014 | 03:27 PM
RandyS's Avatar
Yes, you can install an 'in-line' fuse holder on the power wire to your tach. Any size fuse you have handy will work as the tach will draw only minimal power.
Old Aug 23, 2014 | 11:09 AM
ostie13's Avatar
You were absolutly correct.One row is hot and the other row is Key powered.I hooked the power wire and the lite wire to the keyed side. I like the lite to come on to my tach on all the time. What would you attach to the hot side of that junction box.It has one plug already in it from the factory.
Old Aug 23, 2014 | 02:58 PM
The power supply block is there for the connection of whatever electrical accessories are ordered with the car. Some work only when the key is on, others work all the time. For instance, the power seat works all the time, but the power windows work only when the key is on. The power windows are connected with their main power coming from the always-on side, controlled by a relay that is triggered from the ignition-on side.
Prior to 1971 (in full-size cars - '73, I believe, in midsize cars), accessories were connected to the single IGN, ACC, and BAT spade terminals in the fuse block, and each accessory had a plug with a female pigtail coming off of it that you could connect another accessory to. As time passed, especially in the big cars, people started ordering more and more accessories, which led to more and more spaghetti under the dash, so they came up with these power strips as a solution.
Old Sep 4, 2014 | 08:56 AM
ostie13's Avatar
Ok then will a 5 or 10 watt fuse work then? Or would you put a bigger one in it.
Old Sep 4, 2014 | 07:56 PM
I can't imagine a modern tach using more than an amp, so a 1 amp fuse should be fine, but 2 would be okay, too, and 5 shouldn't hurt anything, as Randy said.
Certainly there's no reason to go any bigger. The mental picture of a tachometer that needed a 20 amp fuse made me laugh out loud.
Redbud40
May 13, 2014 03:04 AM
ragtop442
Jan 26, 2013 10:48 AM
whosyourdaddy
Nov 12, 2010 08:39 PM
Flye
Jul 5, 2009 01:23 PM
supersport
Jan 15, 2009 09:43 PM
