Internal vs external regulation
Old Sep 30, 2014 | 06:25 PM
Dbechtel71's Avatar
Hello what is the difference between external and internal regulation? I guess the real question is when figuring out which wire harness I want to use I noticed that one has the wires that go to the voltage regulator on the wall and my other does not have the wires. If I use the one without the wires to the wall regulator do I need an internally regulated alternator? Hope I didn't confuse anyone
Old Oct 1, 2014 | 02:56 AM
1970cs's Avatar
Lansing built
I had to go back in your history to see what we were working on! 1970 Cutlass S. Factory would be wires headed back to the firewall to the external regulator.
I guess the next question would be which style alternator do you have and which way you do want to go?
Pat
Old Oct 1, 2014 | 06:04 AM
The left alternator is an internal the right is an external. The difference looking at them is the position of the pins on the 2 pin connector.
Old Oct 1, 2014 | 06:17 AM
70cutty's Avatar
Beer Connoisseur
The difference is that externally regulated alternator requires a voltage regulator and internal doesn't.
Old Oct 1, 2014 | 07:31 AM
garys 68&72's Avatar
Before swapping over to internal regulator with a plug and play "kit", read this post.
I ran across the EXACT same issue over at one of the corvette boards.
Either will work if wired correctly.
https://classicoldsmobile.com/forums...rcharging.html
Old Oct 1, 2014 | 01:29 PM
Originally Posted by 70cutty
The difference is that externally regulated alternator requires an EXTERNAL voltage regulator and internal doesn't.
I made a clarification to your post.
Old Oct 1, 2014 | 01:37 PM
70cutty's Avatar
Beer Connoisseur
Thanks.
Old Oct 3, 2014 | 05:13 AM
Dbechtel71's Avatar
Thanks I figured it out
Sampson
Jan 9, 2014 12:12 PM
jims2000lt
Nov 22, 2012 08:22 PM
1970_442
Jul 8, 2010 03:30 PM
redvettemike
May 26, 2009 01:09 AM
