Alt overcharging
Old Jun 11, 2014 | 02:14 PM
kevdog442's Avatar
Member
Alt overcharging
I'm switching the alternator in my 68 Cutlass to a internal type. I bought the conversion kit (adapter plug, and block plug of the regulator) works but I'm getting 16-17 volts. Checked at the battery and with a guage. Took the alternator and had it tested at autozone, and they say it's putting out 14 v and it's fine. Could it be a wiring or ground problem?
Old Jun 11, 2014 | 02:15 PM
kevdog442's Avatar
Member
I meant
Internal regulator type
Old Jun 11, 2014 | 03:05 PM
If the alternator is putting out 14V, there's no way for the voltage to be higher without a transformer. What's the voltage across the batter terminals with the engine off?
Old Jun 11, 2014 | 03:09 PM
garys 68&72's Avatar
Lots of possibilities here. Is the alternator a 1 wire or 3 wire?
Old Jun 11, 2014 | 03:11 PM
Actually it can put out much more than 14V. A failed diode will cause this or if a 3 wire alternator, a voltage drop in the sensor wire.
Old Jun 11, 2014 | 03:22 PM
kevdog442's Avatar
Member
13.5v with engine off. This is a 3 wire. 14v with engine on. When the rpms go up voltage goes up.
Old Jun 11, 2014 | 03:24 PM
kevdog442's Avatar
Member
Also ( not that it matters) but the alt. is new.
Old Jun 11, 2014 | 03:29 PM
Measure voltage at the alt sensor wire. Most likely someone tapped into it causing a voltage drop in the sensor wire to the alternator.
If voltage at distribution point is high and sensor wire reads normal, that's your issue.
Old Jun 11, 2014 | 04:53 PM
kevdog442's Avatar
Member
Ok not really sure what the sensor wire is but here's what I found.
Engine off 12.8v, engine at idle 15v, 2 wire plug that goes into alt 12.7v, terminals on alt were 2.2mV and ~125mV.
BUT today it stayed at 14.5 v. No change with rpms. Seems normal. May be ok now.
I may never know what the deal was yesterday.
Old Jun 11, 2014 | 04:59 PM
billmerbach's Avatar
major noob
Just throwing this out there could your belt be too tight?
Old Jun 11, 2014 | 06:45 PM
kevdog442's Avatar
Member
We'll I did have it off to have it checked. Hmmmm
Old Jun 14, 2014 | 05:49 AM
kevdog442's Avatar
Member
Driving around town yesterday the voltage sometimes got up to 15.5 is that too much? Seems to fluctuate between 14.5-15.5v
Old Jun 14, 2014 | 06:10 AM
major noob
That sounds like a belt issue
Old Jun 14, 2014 | 06:15 AM
OK, check this.
3 wire alternator has the big output wire, a sensor wire (hot all the time) and excitation wire (hot only with key on).
Check the voltage of the output wire when it's high, ie 15 volts. Then check the sensor wire. If the sensor wire is 15 volts too, you have an intermittent diode in the regulator failing.
If it reads normal, ie 13 Volts, you have a wiring issue in the car.
One other note, with the failing diode, the voltage will vary more with engine rpm.
Old Jun 14, 2014 | 08:29 AM
And it's not the belt.
Just because a slipping belt can give you low output does NOT mean that a tight belt can give you high output.
Old Jun 14, 2014 | 08:33 AM
major noob
The old man lied to me and hell denied it but he told me that
Old Jun 14, 2014 | 08:54 AM
"Believe none of what you hear, and half of what you see."
— my Grandmother
Old Jun 14, 2014 | 08:58 AM
major noob
But I trusted my dad
Old Jun 14, 2014 | 11:05 AM
I thought he was joking.....still kinda do....
Old Jun 14, 2014 | 11:07 AM
major noob
Not joking dad told me not to tighten the belt cause it'll overcharge the battery
major noob
Over tighten
Old Jun 14, 2014 | 11:13 AM
If you overtighten the belt, it can damage the belt or the bearings.
Old Jun 14, 2014 | 11:16 AM
major noob
Maybe that's what he meant he just said otherwise lol he's getting old
Old Jun 14, 2014 | 11:26 AM
Well...dad was wrong...
And he really didn't walk uphill to school both ways....
Never drove the car into a bridge abutment because you were misbehaving in the back seat...
You couldn't "walk off" every injury...
And you really were not holding the flashlight wrong when he was fixing something...
Wow, I hope you're not completely disillusioned now.
Old Jun 14, 2014 | 11:32 AM
major noob
I don't how to respond...
Old Jun 14, 2014 | 11:35 AM
Your mom was right about things that could poke your eye out....
But she really never knew anyone that lost their arm hanging it out the car window.
Old Jun 21, 2014 | 07:31 AM
kevdog442's Avatar
Member
Still confused
OK, check this.
Ok so I have a big wire, it reads 15+v. The plug has 2 wires, both have very small voltage. There doesn't seem to be two wires that have at least 12v with engine running.
Can't find any evidence of anything tapped into the wires they all look stock ( just old)
I went and bought another alternator to try and it was above 15v too. So I returned it.
My old alternator with an external reg. never put out more than 13.5v.
So I'm thinking the wires are fine. But I don't know,
Old Jun 21, 2014 | 07:45 AM
When an alternator is putting out a charging voltage it's usually around 14.2-14.5ish volts. Are you sure the meter your using is accurate?
Old Jun 21, 2014 | 07:49 AM
stellar's Avatar
stellar
Take volt readings with key off at battery, at alt post, at alt plug (plug disconnected from alt) on each plug connection. This is 4 volt readings. Make a note of each Test again with key on to run position, engine not running.. Post volt readings. I suspect you may have the 2 alt plug in wires reversed, or sense wire is bad.
Old Jun 21, 2014 | 08:06 AM
What is "very small voltage"?
One wire should have full 12 V when the key is on. It's the excitation wire, it tells the alternator to charge.
The other wire is the sensing wire. It taps off the distribution point (fuse panel/horn relay). It tells the alternator if the voltage is low at the distribution point. If that is reading low, the alternator will try to put out enough voltage to bring it up to about 13 V. That's your issue, your wiring is messed up.
Old Jun 21, 2014 | 08:29 AM
  #31
kevdog442's Avatar
Member
My meter and the voltage guage in the car read the same. So I'm pretty sure it's accurate.
Old Jun 21, 2014 | 08:31 AM
  #32
kevdog442's Avatar
Member
I'll do some more checking but here's what I found earlier.
Old Jun 22, 2014 | 04:04 AM
  #33
I hate to ask this, but did you remove the old regulator and hook the excitation/sensor that were connected to the old regulator directly to the new alternator?
Old Jun 22, 2014 | 06:03 AM
  #34
starfire's Avatar
How about their head?
http://www.wsbt.com/news/local/coron...crash/26499388
Old Jun 22, 2014 | 06:49 AM
  #35
Vomiting out the window of a minivan at 2:00AM.....not the way I want to be remembered or check out.
If I have a choice it will be "blasting across the alkali flats in a jet-powered, monkey-navigated".....nevermind.
Originally Posted by starfire
Old Jun 22, 2014 | 07:05 AM
  #36
kevdog442's Avatar
Member
No I bought one of those conversion kits that has a block that you plug in to the regulator, and a two ended plug that changes the plug type.
Should have been a straight, easy swap that's what has be baffled. I had no problems with my old external reg. setup.
Old Jun 22, 2014 | 07:22 AM
  #37
Wait a minute. Over the past ten days, I lost track of the fact that this was a conversion.
Just connect the alternator the way it's supposed to be connected, without the adapter wiring.
  • Big red wire to the big post on the horn relay.
  • #2 terminal (most clockwise when looking from the back) also to the big post on the horn relay
    (Use ¼" spade female terminals to connect to the two flat alternator terminals).
  • #1 terminal to the brown wire that used to go to the #4 terminal on the regulator
    (Use a ¼" spade male to plug into the flat regulator harness).
Tell us how that works.
Old Jun 22, 2014 | 07:23 AM
  #38
kevdog442's Avatar
Member
Would it make any difference that the kit was for a Chevelle? I ask this because I was looking at how it said to do it in the FAQ (442.com), the terminals that were jumped together on the regulator appear to be different than what was in the kit.
Old Jun 22, 2014 | 07:34 AM
  #39
No, they should be exactly the same.
However, if the instructions were different, that's a different question.
What did the instructions say?
Can you post them?
Can you post a photo of the parts in question, like of the adapter wire laid out flat on a white surface?
Old Jun 22, 2014 | 07:41 AM
  #40
kevdog442's Avatar
Member
Can you post them?
FAQ site:
