Instrument light
Old Apr 17, 2022 | 09:18 AM
OLDsBARRY's Avatar
Instrument light
Have a bulb believe 194 froze in place so need to replace Socket/pigtail. Know where i can get ?
1971 442
-Handbook calls out 194 for the dash courtesy lights (speedo -clock). in 71 these were 2 prong - contact - single filament
-Finally got the burned out bulb out and its a 90 IE (ie??). Assume the 90 is a replacement for the 194. Over the years the contacts had cupped and thus the reason not rotating.
-Found some on Amazon
Old Apr 17, 2022 | 09:28 AM
Can you easily get to the socket and twist the glass off the bulb? Then take a small screw driver and bend bulb metal shell in and use a needle nose plyers to twist it out.
Old Apr 17, 2022 | 10:28 AM
OLDsBARRY's Avatar
Did this on a few other bulb/sockets on the car AND then the spring load was FROZE so assuming im going to run into the same. Will find out but planning for the worst. WELCOME TO MY WORLD
Old Apr 17, 2022 | 10:41 AM
The 194 bulb is all glass wedge base style, so it should be easy to remove.
Perhaps you actually have a different bulb?
Old Apr 17, 2022 | 11:12 AM
Exactly. I've never seen a metal shell on a 194 - they snap in/out.
Old Apr 17, 2022 | 11:15 AM
Every automotive parts store carries 194 bulbs & most hardware stores carry them. They're ~0.75 cents/each.
Old Apr 17, 2022 | 11:17 AM
What vehicle is this for? As Kenneth mentioned, this may not be a 194. Knowing the vehicle could assist.
Old Apr 17, 2022 | 11:36 AM
There are dozens of sockets for 194 bulbs. A photo would help you get useful info.
Old Apr 17, 2022 | 01:39 PM
OLDsBARRY's Avatar
CAR IS: 1971 Cutlass.
BULB callled out in manual: 194 (the 1971 194 Bulb is a small, dual pin bayonet, single)
The SOCKET has spring finger's on its dia to pop in a hole.
What socket do i order?????????????? Anyone know
Old Apr 17, 2022 | 02:20 PM
Clearly more question marks will help...
Is THIS the socket? If so, type cutlass instrument lamp socket into Google. They're sold pretty much everywhere.
Old Apr 17, 2022 | 02:46 PM
A couple dozen more question marks will surely gain you notoriety.
BSiegPaint
Aug 30, 2021 01:46 PM
brucegroesbeck
Jul 19, 2019 10:36 PM
72hardtop
Oct 6, 2015 01:28 PM
68442Convertible
Jul 5, 2012 10:25 AM
70CCV
Jun 17, 2011 05:24 AM
