Inherited a mess
Old May 22, 2026 | 03:23 PM
CaptCutlass1's Avatar
Inherited a mess
Like the title says, I have a mess that I inherited under the hood of my 1972 Cutlass S 350 4bb. Could anyone please help me identify the items in the picture. If you see a black box on the left, I know that's the voltage regulator, but due to having long term brain fog from COVID I just can't remember what the items are in the picture and if I need to clean them up or remove them for my HEI that's already installed. Thanks!
Old May 22, 2026 | 03:33 PM
Does your car have A/C?
Old May 22, 2026 | 04:04 PM
I'm unclear what the relay is being used for in the image you posted - A/C relay(?), something else? Others may have better information. I'll post two PIM images demonstrating the locations of two relays on cars w/ A/C installed. Note the absence of one relay on cars w/o A/C. (The relay located on the right in the below image.) Sorry about your COVID fog.
Old May 22, 2026 | 04:12 PM
I "suspect" the single relay in the image you posted was moved (relocated) from its original position (left of the VR) to accommodate mounting of the MOBILE ALERT Car Security/Starter Disable box. If your car has A/C the A/C relay should be located (about) above the brake booster on the RH side.
Old May 22, 2026 | 04:34 PM
Loaded68W34's Avatar
The relay is actually for the factory grid style rear window defroster. It is wired through the voltage regulator as seen so the grid only gets power while the engine is running. You should have a rear defroster switch on your heat/ A/C controls like the one in the photo below:
^^^THIS^^^
If you're installing HEI, or already have it installed make sure you carry a spare module and heat sink paste in your glovebox. You can get this on Amazon.
https://www.walmart.com/ip/ARCTIC-MX...tiv/6934553913
BTW, that's a bummer about the COVID brain fog. Hopefully it will eventually pass.
Old May 22, 2026 | 05:02 PM
Excellent feedback. I remain dubious of its current location as it does not align w/ the PIM.
Old May 22, 2026 | 05:16 PM
No, it does not.
Old May 22, 2026 | 05:17 PM
It would not be the first time something was moved about to accommodate another device.
Old May 22, 2026 | 05:19 PM
I do have a Rear Defroster, but I believe it is a stand alone switch next to the Headlight Switch since I do not have AC.
Old May 22, 2026 | 05:45 PM
The Rear Defroster an in-glass grid or blower type?
Old May 22, 2026 | 05:53 PM
In glass type. Thanks for those diagram shots!
Old May 22, 2026 | 05:54 PM
Old May 22, 2026 | 05:55 PM
Maybe my Defroster switch is at the right side of the non AC controls now that I think of it. It's been a minute since i looked.
Old May 22, 2026 | 06:03 PM
Located on the left side as an accessory switch.
Old May 22, 2026 | 06:16 PM
Couple diagrams. Note: Image (below) is for non-A/C car.
Non-A/C
Non-A/C
Inside car wiring
Inside car wiring
Old May 22, 2026 | 06:26 PM
It may or it may not mean a hill of beans to some, but the fact is there are actually two items: (1) The Defroster & (2) the Defogger. The Defroster (DEF) is integral to the HVAC system (e.g. blower). The Rear Window Defogger is (as you've stated earlier) a standalone Accessory device.
Old May 22, 2026 | 08:20 PM
Originally Posted by Olds64
^^^THIS^^^
Got it. Thanks for the thoughts. It'll always be a part of me, just not as bad as it was.
Old May 22, 2026 | 08:31 PM
Bingo, that is the location! Nice.
Dippydocus
Jul 9, 2025 06:42 AM
CBowse
Aug 8, 2023 05:28 AM
niko000
Aug 11, 2017 12:48 PM
Gone Johnson
Feb 16, 2017 07:11 PM
srholt45@gmail.com
Nov 20, 2015 10:40 AM
