Inaccurate Tach?
Old Aug 24, 2021 | 06:02 AM
Phoenix8990's Avatar
Inaccurate Tach?
I have a 69 Cutlass and had purchased a NOS tach on Ebay for a 70-71. I figured I could make it work. The casing is where the difference is. I took the internals from the new one and mounted them in the old clock enclosure. It works but something is not right. When the key is off the needle rests at 0, when I turn the key on it jumps to 200 before I start the engine. I never knew if it was just that difference or off more than that. So I purchased a steering column mount tach and wired it up and that seems to be the difference. Any thoughts on what would make it do that?
thanks
Steve
Old Aug 24, 2021 | 06:16 PM
These tachs weren’t very accurate when new. Make sure you have a good ground. Other than that, it might just need rebuilt/recalibrated.
Dors the clock work? If not, get the quartz conversion at the same time. It’s too much of a hassle getting the gauges out of those cars to do it twice.
Old Aug 24, 2021 | 06:57 PM
PatL's Avatar
thanks
Steve
Curious, when you said a NOS tach from ebay. Was it a reproduction or a genuine NOS?.
Old Aug 25, 2021 | 05:36 AM
Genuine, in box. I don't recall exactly but it was about $100
Steve
Old Aug 25, 2021 | 01:15 PM
PatL's Avatar
Steve
You got a good deal Steve !.
musician
Mar 5, 2021 08:25 AM
Bowtie-Bri
Jan 7, 2018 12:18 PM
firefrost gold
May 30, 2014 02:00 PM
Wbland
May 18, 2013 06:21 PM
Wbland
May 18, 2013 03:25 PM
