Ignition lock bezel
Old Nov 13, 2014 | 01:28 PM
jankyrre's Avatar
Ignition lock bezel
Seem that to replace this bezel,the circular plate on the end of the ignition lock has to be removed.
How do I remove this plate?
-68 442.
Old Nov 13, 2014 | 01:35 PM
Tom442's Avatar
one of these?
http://www.ebay.com/itm/68-Olds-cutl...-/151046009939
Old Nov 13, 2014 | 02:21 PM
jankyrre's Avatar
Yes.
The threaded section have a smaller diameter than the endplate on the ignition switch so this has to come off.
Old Nov 14, 2014 | 08:16 AM
Originally Posted by jankyrre
Yes.
Turn to page 12AA-4 in your 1968 Chassis Service Manual, steps 4 and 5 under Ignition Switch Removal. FYI, that "endplate" is part of the lock cylinder. It doesn't come off separately. You have to remove the lock cylinder.
Old Nov 14, 2014 | 02:14 PM
jankyrre's Avatar
It's done,thanks.
When I realised that the acc position was cc from the off pos. it popper right out.
Old Nov 14, 2014 | 03:24 PM
Junkman's Avatar
If you were to see a NOS GM ignition switch, you would note on the inside where the lock cylinder mates up with the ignition switch, there is a slight amount of lubricant. I would suggest a very small smear of Vaseline on the end of the lock switch to lubricate the ignition switch just the way that they were like when new. It will go a long way to make sure that you have removed any resistance between the key switch and the ignition switch.
Wasted
Oct 26, 2018 02:57 PM
88hurstolds
Aug 3, 2014 06:33 AM
randomarrival
Dec 22, 2012 12:28 PM
toms1966rgtop
May 17, 2009 07:19 PM
Tunes67
Nov 27, 2007 03:39 PM
