ignition burning up
Old Oct 8, 2020 | 01:42 PM
oldsguy1964's Avatar
Unhappy ignition burning up
Hello, I am new to this forum and recently bought a 1964 olds dynamic 88 with the 394 in it. i was running it the other day and smelt an electrical fire and immediately saw the key switch was smoking. when i looked under the dash the SOL terminal was glowing red. Anyone ever had this problem? if so, what could it be? P.S. i noticed that the switch is after market.
Old Oct 8, 2020 | 01:52 PM
Had you done any work to the car or wiring just prior to this happening?
Old Oct 8, 2020 | 02:00 PM
No. everything looks to be original with no accessories. except for the nonstock ignition switch
Old Oct 8, 2020 | 02:43 PM
rocketraider's Avatar
Oldsdruid
I've pulled several 64 big car switches and found the connector melted around the red 12v source wire.
If you haven't bought one, get the 1964 Olds factory shop manual. It's a 5 volume set. It has an electrical section with color wiring diagram and you need that to figure out what's going on here esp since switch is no longer a factory style part. Sounds to me like since it's the starter solenoid wire, you may have a solenoid problem down at the starter.
Old Oct 11, 2020 | 02:40 PM
UPDATE: i ordered a new ignition on line and that solved the problem
Old Oct 11, 2020 | 02:53 PM
Good to hear.
dewwhy
Oct 27, 2018 11:18 AM
payan64
Feb 26, 2018 02:15 PM
Rickys61
Mar 20, 2014 03:48 AM
dingusboy
May 16, 2011 11:00 PM
