Identify electrical wired
Old Mar 20, 2023 | 11:46 AM
Earldelk's Avatar
I have a 1972 cutlass. I am replacing the engine wire harness. I can’t figure out where this black and yellow wire connects to.
Where do these wires attach to? 1972 cutlass engine harness
Old Mar 20, 2023 | 11:58 AM
Those go to the "+" terminal of the original ignition coil. Should we assume you have HEI now?
EDIT: I can see the HEI distributor in the photo.
Old Mar 20, 2023 | 12:10 PM
Earldelk's Avatar
Identify yellow and black wires
yes I have HEI. So I should just tape them up?
Old Mar 20, 2023 | 12:12 PM
Earldelk's Avatar
Yellow black wires.
Thanks so much!
Old Mar 20, 2023 | 02:06 PM
rocketraider's Avatar
Oldsdruid
Yup. There's 12v on it so it's a good idea to tape up the terminal end and then secure it so it can't flop around and ground itself.
Old Mar 20, 2023 | 02:26 PM
What is powering your HEI?
Old Mar 20, 2023 | 02:56 PM
Earldelk's Avatar
I believe the ignition wire that is coming from the fuse box. It’s connected to what is labeled “battery” on the distributor.
Puppy boy
Apr 14, 2021 07:58 PM
oldsmoboogie
Mar 12, 2021 02:55 PM
Mark71
Aug 15, 2016 06:30 AM
Microreedy
Jul 19, 2016 08:21 PM
andrew.minarick1
Apr 29, 2011 11:42 AM
