I need a fuel tank sending unit
Anyone know where i can find a fuel tank sending unit for 65 dynamic? Cant seem to find any for the big body olds. Also what body is the dynamic model( A,B )??
I didn't realize it would be so hard to find. I know the 65 tanks the unit is mounted on the front instead of the top. Are there any other vehicles that could cross reference my part?
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
The Dynamic 88 was a "B" body.
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
[QUOTE=65dynamic;795647]Thanks for the info! No return line on mine. 99% sure its bad. Grounded the wire from the tank with key on a gauge works good. Sending unit stuck at 1/4 tank. Wow, just found a NOS on oldsobsolete but they want $345! Hopefully i can cross reference the number you gave me and find something cheaper.
/QUOTE]
/QUOTE]
You have one! So why don't you send it out for repair? Bobs speedometer
http://www.bobsspeedometer.com/1/120/services.asp
Pat
Pat
![Lightbulb](https://classicoldsmobile.com/forums/images/icons/icon3.gif)
There, you have another option. It is probably best to remove the sender from the tank before condemning it completely. Flooded. partially flooded floats, and stuck arms have also been known to cause erroneous readings.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
68RocketAction
December 18th, 2014 11:19 AM
1carsick
October 17th, 2012 09:10 AM
