I need a fuel tank sending unit
Old Feb 26, 2015 | 03:41 AM
65dynamic's Avatar
Anyone know where i can find a fuel tank sending unit for 65 dynamic? Cant seem to find any for the big body olds. Also what body is the dynamic model( A,B )??
I didn't realize it would be so hard to find. I know the 65 tanks the unit is mounted on the front instead of the top. Are there any other vehicles that could cross reference my part?
Old Feb 28, 2015 | 10:26 PM
Ozzie's Avatar
Question
I don't know where you can find one. The group number is 3.107. The part number should be 6426052 with the return line and 6426051 without the return line. Are you sure that yours is defective?
The Dynamic 88 was a "B" body.
Old Mar 1, 2015 | 04:59 AM
65dynamic's Avatar
Thanks for the info! No return line on mine. 99% sure its bad. Grounded the wire from the tank with key on a gauge works good. Sending unit stuck at 1/4 tank.
Old Mar 1, 2015 | 06:17 AM
65dynamic's Avatar
[QUOTE=65dynamic;795647]Thanks for the info! No return line on mine. 99% sure its bad. Grounded the wire from the tank with key on a gauge works good. Sending unit stuck at 1/4 tank. Wow, just found a NOS on oldsobsolete but they want $345! Hopefully i can cross reference the number you gave me and find something cheaper.
/QUOTE]
Old Mar 1, 2015 | 06:49 AM
1970cs's Avatar
Lansing built
You have one! So why don't you send it out for repair? Bobs speedometer
http://www.bobsspeedometer.com/1/120/services.asp
Pat
Old Mar 1, 2015 | 06:52 AM
65dynamic's Avatar
I didn't know i could do that. Thanks for the link!
Old Mar 1, 2015 | 08:00 AM
Ozzie's Avatar
Lightbulb
There, you have another option. It is probably best to remove the sender from the tank before condemning it completely. Flooded. partially flooded floats, and stuck arms have also been known to cause erroneous readings.
Old Apr 2, 2015 | 06:16 AM
radioburningchrome's Avatar
This one is cheap:
http://www.ebay.com/itm/1965-Oldsmob...e41456&vxp=mtr
Old Apr 2, 2015 | 06:32 AM
65dynamic's Avatar
Old Apr 2, 2015 | 07:23 AM
m371961's Avatar
Have you removed it? Checked the ground from sender to body?
Mine was missing the ground strap in the sender from the winding to the sender body.(Inside the tank on the sender)
Old May 8, 2015 | 03:29 PM
65dynamic's Avatar
Thanks again for the link radioburningchrome! Picked it up for $7. Just installed it and I finally have a working fuel gauge again.
Old May 8, 2015 | 06:31 PM
m371961's Avatar
Can't beat that price. Glad you got it.
dallasite21
Oct 1, 2021 05:21 PM
pfergy600
Oct 4, 2014 05:29 PM
1carsick
Oct 17, 2012 09:10 AM
wikkonado
Jun 19, 2010 07:28 PM
