Horn wire from steering column
Hi. I have purchased a 1970 Cutlass with chopped up electrical and am working towards getting it road ready.
I have removed the instruments and dash.
Currently, there is no horn relay in the car. The horns are there but no relay. I can't find the wire from the horn button on the wheel. The wheel itself is a 4 spoke sport wheel and I still need to purchase the spring/pin/clip that holds the rocket emblem center cap onto it. However, my problem is I can't figure out which wire leaves the steering column to control the horn. I do have a service manual but I still can't seem to find the darn wire. I've been continuity testing from the 'button hole' to everything I can find but to no avail.
Any ideas? Pic attached shows the mess I have...
I am hoping to verify the wire at the steering column and then chase it through the firewall. Problem is I dont know where it comes out of the column. I see two harnesses but cannot verify continuity to the horn button. Perhaps I need to pull the column apart.
Just to close this out and perhaps make someone else's life easier...
The horn switch feeds through terminal 'G' on the harmonica connector. Initially I couldn't verify continuity so I pulled the lock plate off and discovered dirt and corrosion on the back of the plastic ring (canceling cam?) and on the copper contact on the column.
This car has been sitting a lot for the last three years. I bet if it was used, and the wheel was turning all the time, this would not have happened. Problem solved with some scotch brite.
Thanks for all the input.
Pretty sure the horn relay on a 70 is on the firewall, above and to the right of the distributor. Assuming the harness isn't hacked up to much there should be a green wire (horn) a black wire (provides a ground from the horn button) and a pink with black tracer ( if I remember correctly this is a signal wire from the ignition lock cylinder, provides that annoying buzzer when the key is in the ignition and the door is open) and several large wires with fusible links that provide power to the fuse box, alternator, blower relay (if the car had A/C) etc. Hope that helps.
Thanks for letting us all know what the problem was.
68RocketAction
October 15th, 2016 01:29 PM
