Horn Relay/Key Buzzer Wiring HELP!!!!!!!!!!
My mechanic is stuck, even after buying the 11 x 17 color schematic off Ebay (which is wrong BTW) we are down to the stupid key buzzer/horn relay. so I've attched a pic. if anyone has a rundown on what where, I'd be more than delighted, name your price... Please be as specific as possible... Thanks in Advance!!!
From what I can tell . Large black wire should be pink/blk tracer this wire goes thru firewall connector to the ignition switch probably been spliced at some time in past. Dark green is power to the horn. Small black wire goes to horn button. The reds go to the battery the alternator and the head light switch.
This exact question has come up before.
The Chassis Service Manual is very clear on this.
The scan below is from the CSM in WildAboutCars (I gave away my last hard copy with my last '68 Olds), but it should show it clearly enough.
![](/forums/attachments/electrical/38421d1325815013-horn-relay-key-buzzer-wiring-help-1968-horn-relay-diagram.jpg)
ELECMAN
January 26th, 2010 10:59 AM
