Horn Relay/Key Buzzer Wiring HELP!!!!!!!!!!
Old Jan 5, 2012 | 03:14 PM
1968 cutlass's Avatar
My mechanic is stuck, even after buying the 11 x 17 color schematic off Ebay (which is wrong BTW) we are down to the stupid key buzzer/horn relay. so I've attched a pic. if anyone has a rundown on what where, I'd be more than delighted, name your price... Please be as specific as possible... Thanks in Advance!!!
Old Jan 5, 2012 | 03:41 PM
OLDSRALLYE350's Avatar
From what I can tell . Large black wire should be pink/blk tracer this wire goes thru firewall connector to the ignition switch probably been spliced at some time in past. Dark green is power to the horn. Small black wire goes to horn button. The reds go to the battery the alternator and the head light switch.
Old Jan 5, 2012 | 04:41 PM
That's great, Thank you!!! Can you explain the 1 tab/prong that has no wire connected to it? What is that prong for???
Old Jan 5, 2012 | 05:24 PM
olds1968's Avatar
member
the blk/pnk wire goes on that connector from the ignition switch. thats what makes the buzzing sound when you open the door and leave the key in the ignition.
Old Jan 5, 2012 | 05:59 PM
This exact question has come up before.
The Chassis Service Manual is very clear on this.
The scan below is from the CSM in WildAboutCars (I gave away my last hard copy with my last '68 Olds), but it should show it clearly enough.
kstern58
Mar 7, 2015 10:22 AM
acloud
May 31, 2013 07:43 PM
Al Graaf
Oct 16, 2012 07:24 PM
mmurphy77
Dec 9, 2011 08:31 PM
ELECMAN
Jan 26, 2010 10:59 AM
