Horn relay 69 Cutlass S 350
Old Apr 23, 2013 | 03:44 PM
Bob69Cutlass's Avatar
Hi All,
Doing some rerouting of wiring along the driver side wheel well. Would like to move the horn relay/key buzzer to a non-metallic surface. Looking at fig 12-1 in the 69 Chassis Service Manual it does not appear that this item needs metal grounding but I would others with more electrical knowledge than myself to review this.
Thanks in advance.....Bob
Old Apr 23, 2013 | 04:00 PM
I believe you are correct, if not you can always run a ground wire to one of the mounting screws.
Old Apr 23, 2013 | 06:35 PM
I don't think it needs a ground. The horn button provides the ground to the horn relay coil, same thing for the annoying key in the ignition buzzer.
Old Apr 24, 2013 | 07:54 AM
Yes, you are all correct.
Old Apr 25, 2013 | 06:08 AM
Thank you all for responding.....
pcard
May 14, 2014 01:21 PM
tcarroll
Jul 16, 2012 04:21 PM
gman
Jan 13, 2012 07:43 AM
JustJordy
Nov 9, 2010 10:44 AM
wanderalone
Oct 20, 2010 07:20 AM
