Horn doesnt work
The horns on my 442 sounded like dieing geese. I took them off and replaced them with parts store horns...BINGO! The originals sounded like miracas because they had just disintegrated on the inside. You never know....they are 45 years old after all.
Before condemning the original horns, try a slight tweak on the current adjustment screws on the horns themselves.
Try 1/10 of a turn CW first. If not go back to original position, then 1/10 of a turn CCW.
Sometimes the internal contacts get corroded and need a little more pressure from the screw to make it work.
Just make not of where the original position of the screw is first!
All I have ever gotten from twiddling with the adjuster is a different horrid noise. In MI they rot away inside. When the '85 needed horns I went to the local yard and got Cadillac horns. Now it sounds like a huge car of course.
To fix your horns follow the CSM procedure.
Your steering wheel contact has to make the relay actuate, which sends power to the horns. Not much to it. Most troubleshooting can be done at the relay which will show if the issue is towards the steering column or towards the horns. Or, the relay itself.
Just something to try before chunking them or even removing them.
A slight tweak, not much. I fixed both horns on a 2005 kia this way also.
TK-65
March 14th, 2010 07:06 PM
