Hood light
Old Jan 5, 2011 | 06:02 PM
MHENDERSON's Avatar
Question Hood light
1971 Olds
Old Jan 5, 2011 | 06:38 PM
alek72us's Avatar
Olds Dreamer
Originally Posted by MHENDERSON
Do they sell aftermarket lights that go under the hood and work when opening?I have taken 3 from olds cars in the junkyard with the mercury fuse. I got one working but it does'nt now.Can you buy kit to rebuild them.I no the mercury is outlawed.
i have taken a couple from 3rd gen cam#ros u have to have a metal hood or run a ground up to it but it shuts off when the hood is closed and turns on when hood is open. if this helps.
Old Jan 5, 2011 | 07:55 PM
W70442's Avatar
under hood light
You could still get them over the counter at the dealership as recently as a couple years ago.
The numbers I have are 983173, 939035, 983386, 995558 and the most recent one, and the one you'll likely get is 22529281.
Good luck,
Randy
Old Jan 6, 2011 | 05:30 AM
Lady72nRob71's Avatar
I know of no rebuild kits.
If you are thinking about aftermarket, then is seems that original look is not too important. If that is the case, the local boneyard is the place to go.
Look at all 70s to 90's GM cars - not just Olds. My '86 Cutlass uses a similar looking light as the 72. My Caddy has an enclosed plastic one that uses the merc switch, too.
Most yards will guarantee they work and they should be cheap.
The question is do you have the yards around and do you have the time...
Old Jan 6, 2011 | 10:44 AM
MHENDERSON's Avatar
Thanks Rob.I have got 3 of them and I made 1 that worked for a short time.I do like the original look my 1st choice.When I go back to Ayotte's in Poland me I will keep looking.They have alot of Oldsmobiles from the 60 big boats hardley touched.
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
jensenracing77
Dec 11, 2013 08:22 AM
Ddbord
May 6, 2013 06:12 AM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
georgiaboy697
Jul 2, 2010 09:23 PM
