Holley Terminator Max and stock console RPM gauge
Reading the manual for the Terminator X Max and it says "Tach Output wire provides a 12V square wave output and can be used to trigger a conventional tach"
Which wire in the engine bay can I tie this wire to for the tach to work? If anyone has a link to the wiring schematic that would be awesome.
Appreciate the help. THANKS!
THANKS AGAIN!
I don't know anything about the Holley system, but the factory tach is designed to connect to the NEGATIVE side of the coil. With the conventional points-style ignition system that terminal oscillates between 12V and ground, depending on whether or not the points are open or closed. GM's factory HEI has a TACH terminal that replicates that signal for tachometer use. If this is also what the Holley system does, then you are fine.
