High voltage on 67 Cutlass 442
while driving around town I noticed the generator light came on and I looked at my SW votmeter and it was at 16+. No noises or running problems or smells or smoke. I could let off gas and it would sometimes drop to 13+ for a short while then climb back to the 16 as I accelerated back to 40 mph. Is that what I remember on an old 67 chevelle I had with the alternator and it was the diode trio inside the alternator ? or is it a bad alternator? or something else? thanks Mike
A 67 alternator does not have a trio unless it was replaced with an alt from a later year. Other reasons for over charge are a bad ground, a bad battery or a battery that is low on water, an open or bad connection to the regulator number 3 terminal.
old battery dead and will not charge up! replaced battery with new and same results GEN light stays on, put new regulator on and same issues, GEN light stays on. bought new reconditioned alternator and still same issue. What is next?
Was anything done to the car just before this gremlin or did it come about "out of the blue"?
What is the charging voltage across the batt terminals?
What is the voltage with it running from the alt output stud to ground?
If the alternator is unplugged does the light go out?
Check the ground strap from the engine to the firewall...it is on the back of the head if I remember correctly.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Steven Hall
March 22nd, 2019 07:17 AM
