High Speed Fan always on even when car is off
I put in a new hi-speed fan relay and connectors as they were fried and not in use for years. Lo and behond, the blower comes on high, but even if the car is off. When I try to adjust the fan speed to "Lo", the fan still runs on high whether car is off or on. Any ideas? I am just started digging.
3 things I can think of, my Dad messed with the wiring years ago - I remember he had installed a switch inside the car underneathe the A/C controls, but I did not notice it there , but I did not look too hard.
2) The manual says it runs on vacuum and I know the power door lock don't work anymore, so I don't know how well the vacuum is working on the switch.
3) Perhaps some grounding issue.
Attached is the blower diagram.
another possibility-the contacts are welded together(stuck closed)
unplug the connector from the relay to check this. if the relay clicks when you unplug it or plug it in, the coil is being driven by a power source. if it doesn't click, the contacts are welded together. all of this assumes proper wiring connections exist.
bill
bill
Hi Bill, thank you for your reply. For clarification, what could be welded together? Inside the relay? The relay connectors? It did the same thing with both the old and new relay if that helps.
Something that may offer a clue. I have the A/C Comfortron Thermostat. When the car is off, with the relay plugged in, the blower blows HI. When I adjust the thermostat to 65F, the A/C kicks on. When I put the fan speed on OFF or LO, the blower blows HI. When I put the fan speed on HI, DEFROST or DE-ICE, the fan blows low. The A/C blows ice cold.
Bill has nailed it. The ONLY way for this to happen is for the high speed blower relay to go bad. The contacts inside the relay arc every time it is used. As these contacts get pitted, resistance increases, causing the contacts to weld together. This is what has happened. Replace the high speed blower relay.
If you pull the connector off the relay, does the motor turn off? If so, check for continuity between the motor contact on the relay and the +12V contact on the relay. If you get continuity, you have a bad relay. If not, you have bad wiring.
That diagram is awesome Joe.
When I disconnect plug, blow shuts off. There are two plugs going to relay.
3 pronged plug has
1) black coming from battery
2) brown going to blower
3) black going to blower
1 prong plug has:
1) light blow going to blower
How should I check continuity? I get 12 volts when I touch the black from battery plug with anything else.
3 pronged plug has
1 prong plug has:
3 pronged plug has
1 prong plug has:
3 pronged plug has
1 prong plug has:
By the way, take the old relay and remove the cover by bending the tabs. You can then see exactly which terminals on the relay correspond to the functions as shown on the diagram. One terminal will connect to the control coil - that one must be wired to the dash switch. One will be the common contact, which must be wired to the blower motor. The normally closed contact is wired to the speed control resistor, and the normally open contact is wired to the battery.
Joe, you got me thinking , would the power plug for the battery be the one that is all the way to right (the lone prong)? Right now I have it as part of one of the three.
For checking continuity , where do I put the positive and where the negative exactly? Connector plug? Relay? That is where I am missing.
Continuity doesn't care about polarity. All you are checking for is a copper path between the test probes. If you probe the relay terminals, you will get continuity from one terminal to ground. That is the control coil and must be wired to the dash switch. You should then get continuity between two of the remaining three terminals. Those are the normally closed terminals. Apply power to the control coil terminal (+12v) and you will hear the relay click. Now check continuity on the remaining three terminals again and you should see that two different terminals are connected. The one terminal that was common goes to the blower motor. The one that was connected to it without power goes to the resistor. The remaining one goes to the battery.
Folks, this is all good info, but Matchek's second post says its COMFORTON which uses a different blower motor control circuit than the one posted.
We'll need a COMFORTRON wiring diagram to properly diagnose this issue.
The first thing to do is to verify that all vacuum connections are correct. The power servo that controls motor speed is inside the passenger compartment, on top of the HVAC box.
PROBLEM SOLVED! Thank you gentlemen! Joe, by the way, where you did you get that wiring diagram? Not sure if I saw something like that in my manual.
It appears that the wiring of the relay plugs were incorrect. Looking at Joe's wiring diagram, and looking at the relay, it appeared that the power source was not wired in the correct location. But, Joe's wiring diagram is for a different year or maybe not Comfortron, the wiring colors did not match, so I guessed on the other two wires, and the other two wires could not tell if went to controller or resister as under black protector.
My first guess with other two wires yielded the blower off with power off, which is good, also LO fan worked witht controls, but no HI fan.
My second guess, interchanged the other two non-power plugs wiring, yielded perfect A/C fan controls!!!!!! HI, LO, and OFF when on OFF.
Thank you so much for your help with info and ideas! The A/C has not blown cold air in 15 years and now it is ice cold (knock on wood) and all the fans work properly.
My Dad said he never messed with the relay so he doesn't know why the wiring was off there, but anywho - all good now!
