High beam indicator
Old Jul 30, 2011 | 06:17 AM
msco123's Avatar
High beam indicator
My high beam indicator does not work. I have pulled the gauge and checked the bulb and it is good when I hook it a direct power source. I does appear the some bulbs are dimmer or not working on one side of the gauge. But all bulbs check out when directly powered. Any suggestions?
Old Jul 30, 2011 | 06:32 AM
CQR's Avatar
CQR
May need a little more information. Year, Model, etc. Usually dim bulbs are a bad ground issue.
Old Jul 30, 2011 | 06:52 AM
Lady72nRob71's Avatar
Clean contacts of bulb sockets, circuit board pads, and cluster connectors.
Old Jul 30, 2011 | 07:00 AM
The indicator lamp is powered from a wire that comes directly off the dimmer switch. If the high beams come on, there is power at the output of the switch. Start there. Disconnect the wires from the dimmer switch and apply +12v to the high beam wire. If the indicator lamp still doesn't come on, trace the circuit. Check this wire for continuity where it plugs into the instrument panel connector. If bad, fix the break. If good, check the connections on the indicator lamp socket. Be sure the ground side is making contact also.
Old Jul 30, 2011 | 07:08 AM
msco123's Avatar
Appreciate the help, guys. Car is a 73 cutlass supreme.
Old Dec 3, 2011 | 10:45 AM
RenderPit's Avatar
Cruizin
Good info, thanks
Trentg89
Feb 14, 2015 07:16 PM
RenderPit
Ninety-Eight
21
Jun 8, 2013 04:52 PM
woody30
Tech Editor's Desk
Sep 15, 2012 08:45 AM
kandelino
Nov 5, 2010 06:45 AM
BaileyJD1
May 1, 2008 11:45 AM
