hei conversion
Old Oct 3, 2015 | 06:51 AM
jwr7042's Avatar
hei conversion
Will an hei distributor clear an oai system. What about the vacuum advance clearing the firewall. I purchased a new dist and wires but the dist is quiet a not bigger than stock. This for a 70 442 w30.
Old Oct 3, 2015 | 07:00 AM
The vacuum advance will clear the firewall, however you may have issues with the OAI air cleaner clearance.
Old Oct 3, 2015 | 12:52 PM
jwr7042's Avatar
Hei:
Is there an hei distributor with a smaller cap that would work with oai air cleaner?
Old Oct 3, 2015 | 12:55 PM
Are you just wanting to do away with points? If so install a points replacement setup like Pertronix and use your original distributor.
Old Oct 4, 2015 | 12:18 PM
jwr7042's Avatar
oai
has anyone used a oai with an hei conversion?
Old Oct 4, 2015 | 01:12 PM
jensenracing77's Avatar
You have to modify the back of the air cleaner base to make it work together. That or just put a Pertronix pickup in the stock distributor and not have to modify the base. I have a non OAI base that is modified for this but it has the small snorkel on it. I would not modify the stock OAI base because it is worth to much money.
Old Oct 4, 2015 | 05:05 PM
I merged your 2 threads, I asked a question on your previous question and never gotten an answer from you.
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
buds68a77
Tech Editor's Desk
Dec 2, 2009 08:01 AM
Frankenpez
Feb 8, 2009 07:38 PM
JoshF85
Mar 15, 2005 10:50 AM
