Heater dont work
Old Jan 22, 2016 | 10:14 AM
toronado70's Avatar
Heater dont work
Suddenly the fan to the heater stoppet working. It`s not the fuse. Any suggestions?
Tedd
Old Jan 22, 2016 | 11:59 AM
Originally Posted by toronado70
Any suggestions?
Tedd
Yeah, do some basic troubleshooting.
Do you get +12V at the wire to the motor? Does the motor run if you jumper +12V directly to the terminal?
Old Jan 23, 2016 | 02:18 PM
toronado70's Avatar
Thanks. I will try your suggestions, but i will wait untill i get the shop manual. I am not very experienced
Old Jan 23, 2016 | 02:47 PM
Octania's Avatar
While it is always a good idea to have a wiring diagram and Chassis Service Manual on hand, it is pretty basic to remove the wire from the motor, ck for voltage at the wire with light or meter or buzzer or etc.
If no volts, THEN you might need the manual for under-dash details.
If yes volts, then apply your own 12V to the motor lead right from the battery and see if the motor spins. One would assume not, if there was already 12V present at the wire.
Motor not spinning when fed 12V indicates a bad motor- or not grounded well perhaps- also easy to check with test light or meter. One might tap the motor lightly while it has power and see if you get one last run by jiggling stuck brushes into place. Or, just replace the motor.
"Just" can involve quite a bit of access dismantling depending on your exact model and whether AC stuff is involved.
Oh and there is sometimes a separate fuse inline under the hood for high speed of the fan motor.
punishercarr
Jul 8, 2018 06:47 AM
44blue
Aug 28, 2015 04:54 PM
Cutdawg78
Jul 10, 2012 05:04 AM
coppercutlass
Jul 30, 2011 02:36 PM
1983oldsmobiledelta
Oct 2, 2010 05:54 PM
