Heater/AC fuse keeps blowing on the '66
Old June 30th, 2014, 04:47 AM
car nut farmer
71rocket's Avatar
Like the title says, the fuse keeps blowing when I turn on the ignition. I've disconnected the wires in the engine compartment in an effort to isolate the problem but that hasn't worked. I now figure it's time to look under the dash and find the short. Is there any one problem area I should look at, is this a common problem? What should I look at first?
71rocket is offline
Old July 31st, 2014, 05:25 AM
car nut farmer
71rocket's Avatar
ttt
71rocket is offline
Old July 31st, 2014, 09:36 AM
Oldsdruid
rocketraider's Avatar
There's probably a master switch on that control head somewhere and if A/C also a compressor switch on the temperature lever. Those are where I'd look first. They're bimetal spring type switches and I've seen them get bent out of shape and contact stuff underdash. You'll usually see a spark or small flash of light behind dash if the switch is wacky.
Past that, trial and error. Run continuity checks on all the associated wiring and make sure nothing's chafing against dash support structures.
rocketraider is offline
Old August 2nd, 2014, 05:25 AM
car nut farmer
71rocket's Avatar
Thanks. This is something I'll be addressing this fall before the cold weather sets in. Need some heat.
71rocket is offline
Old August 2nd, 2014, 06:20 AM
Octania's Avatar
I have seen wires chafe thru the insulation WITHIN the fuse box/ distribution block, on a '66 442. Tough to find. It was noticed during the refurbishing of the car.
As for troubleshooting...
physical inspection especially where any contact is made
Start disconnecting sections of that circuit from the end [motor] on towards the battery, until problem stops.
Maybe hotwire an ammetered wire right from battery to blower motor and ck its actual current draw- maybe it is just failed inside and there's your problem. EASY fix compared to wire fault finding.
Octania is offline
Old August 2nd, 2014, 01:26 PM
RandyS's Avatar
X2 I would start by unplugging the blower motor and see if the short is still there. If it is, you have a wiring problem, if not, it's the motor itself.
RandyS is offline
Old November 7th, 2014, 05:23 AM
car nut farmer
71rocket's Avatar
Every thing from fuse block forward is unhooked and fuse still blows, under the dash I go.
Thanks for the tips
71rocket is offline
Old December 8th, 2015, 11:10 AM
aardvark's Avatar
what did it end up being? i'm having a similar problem right now and can't find the short.
aardvark is offline
Oldscutty72
December 28th, 2015 01:56 PM
Chris J
May 27th, 2013 07:58 PM
CutlassLegend
September 12th, 2011 03:28 PM
dc2x4drvr
September 14th, 2010 08:54 AM
Big John 85
June 14th, 2009 05:37 PM
Quick Reply: Heater/AC fuse keeps blowing on the '66
