Headlight Relay
Old Oct 24, 2025 | 11:46 AM
Taz54904's Avatar
Headlight Relay
I finally got around to adding relays to my headlights. It was going to be an "off season" project but the wife and I still love running the 67 in the fall, even though it's getting dark quicker, so I thought I might as well knock it out.
I can't take credit for the photo below. I took a screen shot off of a video and added my notes for my project.
These are the before photos -
And these are the After photos -
The before and after photos were taken with the engine off.
(Don't mind the wires in the "after" photos, I took care of those after I made sure everything was working properly.)
Old Oct 25, 2025 | 05:40 AM
OLdGreenPaint's Avatar
Looks like you made a significant improvement in getting the juice to the bulbs. I noticed that the headlights on my 72 look much like your Before pics. I carefully cleaned the bulb barbs and connector brass, it didn’t make much of an improvement. So if I have a wiring/connector corrosion or oxidation problem it is somewhere else. Where did you mount the relay?
Old Oct 26, 2025 | 04:40 AM
Taz54904's Avatar
Correct. There is minimal voltage drop at the lights now.
Have you checked your grounds?
I haven't mounted the relays yet. For now, they are behind the battery, laying on the inner fender. This off season, I am pulling the motor and detailing the engine bay. That's when I'll permanently mount the relays
Old Oct 26, 2025 | 05:50 AM
I am going through engine bay as well, but not removing engine. So as I get to any ground connection point I am cleaning them up. I would have to go look and see where the headlight grounds are? Surgery anesthesia is making my mind a little sketchy and don’t recall? I didn’t think of doing it, but I could do a voltage reading at the headlight connectors to see what they show. Maybe even a headlight switch issue? 53 years old now.
Old Oct 26, 2025 | 07:19 AM
Taz54904's Avatar
That's what I did, I took voltage readings at the lights.
On the 67, two headlights share one (small ga) ground wire.
Old Oct 27, 2025 | 12:51 PM
Taz54904's Avatar
Here's the voltage drop (in percent). This is comparing (non running engine) voltage to the voltage at the lights.
Before adding relays
Low Beams - 7.8%
High Beams - 14%
After adding relays
Low Beams - 0.8%
High Beams - 5%
Old Oct 27, 2025 | 01:41 PM
fleming442's Avatar
The high beam switch is a choke point. You effectively end up with a series switch situation, which is 2 mechanical connections. I'm a big fan of eliminating load from switches, even with the added points of failure.
Frod used standard 5 pin relays for fuel pumps in the 80s, so most parts stores stock them. I'd venture they're more readily than a floor mount, high beam switch from the 60s.
I'm in that dilemma right now. I like having available parts, but the waterproofing and packaging are obstacles. I think I have settled on the MSD SSRs in 4x35a configuration. 1 for fans, 1 for lights under the hood and 1 inside with 1 spare.
Old Oct 27, 2025 | 01:46 PM
Taz54904's Avatar
I put a spare relay in the glove box right away. Just in case.
Giftman23
Oct 12, 2024 11:52 AM
8691ecirpac
Nov 9, 2023 10:28 PM
scott_442
Aug 9, 2021 07:08 PM
Asusport
Jun 14, 2017 06:59 PM
