Hazard warning switch
Old Mar 18, 2011 | 10:00 PM
SkylinesSuck's Avatar
'75 Cutlass Salon, non-tilt steering wheel. The only switches/arms I have on the column are the turn signal stalk and the hazard switch. My problem is the hazard switch is flaky I believe. The turn signals work great, but the hazards will randomly blink the left or the right only, sometimes quickly, sometimes slowly unless I am physically pushing the switch in with my pinky, and even then I have to wiggle it around a little to get it working right. If I stop applying force, they start acting funky. I have replaced the flasher module and external hazard "button" but I think it's what's inside the steering column that's the problem.
I'm thinking I need to replace the whole turn signal switch assembly i.e. this:
http://www.autozone.com/autozone/par...59503_57574_0_
or this:
http://www.autozone.com/autozone/par...questid=157143
Any input would be greatly appreciated. Also, it looks like I am going to have to remove the steering wheel to get at this, is that correct? Will I need a special tool for this--or more specifically, can I make do with out the tool? I'm in Japan so I can't pop down to autozone and rent a tool. Thanks!
Old Mar 18, 2011 | 10:34 PM
Sounds like the return springs are not bringing the switch fully and reliably back to center.
Easiest thing is probably just to replace the switch.
You DO have to pull the steering wheel to get to the switch.
Why not just order a steering wheel puller when you order the switch?
Steering Wheel Puller
Steering Wheel Puller with a fancy case (Japanese will love it)
The job will be easier with a lock plate compressor (I'm pretty sure the '75 has the spring-loaded plate), but I prefer to save my $20 and just fiddle with 2 screwdrivers.
Lock Plate Tool 1
Lock Plate Tool 2
Old Mar 19, 2011 | 03:08 AM
Great, thanks. So either of the switches I linked will work for my specific application? The reason I ask is I think Ive heard people talking about different options of dimmers on the column and tilt steering and what not.
Old Mar 19, 2011 | 04:48 AM
Okay, so I'm reading a little more in detail in the descriptions of these switches on the autozone website, and it appears one is for "cornering light equipped" cars, and the other isn't. What are these cornering lights they are describing? I don't think I have any bright lights that light up when I hit the turn signal lever if that's what it's talking about (I don't think.)
Old Mar 19, 2011 | 06:29 AM
They are big signal lights that don't flash.
Jacob Wilson
Jun 26, 2014 07:34 AM
BeenThere
Feb 10, 2013 07:03 AM
JimpeBoy
Jun 12, 2011 12:56 PM
Rex
Apr 15, 2011 09:19 AM
HouTXCutlass
Jan 13, 2010 10:14 AM
