ground for front window
Old Dec 29, 2013 | 06:25 PM
Bills72's Avatar
i am at the end of a rebuild and i am putting in a new front window with a antenna in it and i have a new ground, but trying to remember how it hooks up? thanks again.
Old Dec 29, 2013 | 07:15 PM
I don't believe the 72 has that ground feature you're talking about. Are you thinking of the u shaped spring that was used on earlier models to make contact with the hood and cowl?
Old Jan 1, 2014 | 11:16 AM
Bills72's Avatar
i remember taking it off and i have kept every part to ensure I got the right thing if it needed to be replaced. It goes from the cowl to the window it is the ground for the antena inside the windshield. i just can't remember how it goes, it has been a few years and i can't tell on my pictures i took they are to far away.
Old Jan 1, 2014 | 03:55 PM
Bill, I don't have this on my 72 but is this what you're talking about?
Old Jan 2, 2014 | 04:18 PM
Bills72's Avatar
Why yes it is and if I don't have to have it that would be just fine, but I am planning on having a windshield with a antenna in it
Old Jan 2, 2014 | 04:31 PM
That shouldn't be an issue at all. All the 72 A bodies had the wind shield antennas (there was an optional non antenna wind shield for cars without radios though). That clip is not essential and I'm positive (have to check the AM) it was deleted during 1970 production. My 72 does not have that, but does have the static and distributor resistor to reduce/eliminate whine or static.
Old Jan 2, 2014 | 04:58 PM
Bills72's Avatar
Thanks a lot I have the distributor and a few other resistors hooked up, thanks for all the help
JPMDaddy
Oct 20, 2013 08:21 AM
jpc647
Dec 10, 2011 10:29 AM
projectheaven
Jan 1, 2009 09:58 AM
Chumley
Mar 22, 2007 10:03 AM
