Got it running
Old Jul 9, 2009 | 06:01 PM
85cj7's Avatar
Got it running
Got my car running for the first time today. Its been sitting for 10 years. Put on HEI distributor, alternator and it fired right up. Smokes bad right now, maybe it will clear up.
One question. Where is the best place to get the 12 volts for the HEI distributor. I have it wired straight to the battery right now just to get it running.
Old Jul 10, 2009 | 05:21 AM
Oldsguy's Avatar
Past Administrator
Congrats! Some people use the horn relay to tap off from.
Old Jul 10, 2009 | 05:40 AM
The HEI distributor needs 12 volts ignition. You can either use the horn relay or you can disassembly the dash and run another wire from the 12 volts ignition that went to your coil originally. If you still have the 12 volts ignition resistor wire in the engine bay you can attach another wire to it and pull it through the fire wall.
OldsGMC455
Jul 13, 2015 05:03 AM
Carl, uk
Mar 13, 2014 05:43 AM
ccrain
Jan 17, 2014 09:37 AM
84oldsDelta88
May 16, 2011 05:50 AM
dan2286
Jan 29, 2010 11:06 PM
