Gas gauge goes past full?
I have read some of the other post with this issue, but not sure where to start checking for the issue I am having. I have a new tank and sending unit installed and the gauge seems to work correctly until I turn the headlights on. When I pull the headlight switch the needle wraps around to about the 3 o'clock position.
Something not grounded in the light circuit maybe?
Thanks!
Thanks!
Just tap the gauge with your knuckle or fingernail and it should go back down. Just a loose nut behind the dash that grounds the gauge to the dash. Mine does this a lot and I get all excited then I realize I don't really have that much gas in there. Gets me every time.
-Andres
-Andres
JPMDaddy
January 31st, 2020 04:01 AM
KDW
March 2nd, 2015 04:17 PM
442much
May 5th, 2011 05:48 PM
