gas gauge (fuel gauge)
Old October 6th, 2022 | 12:53 PM
Bills67's Avatar
does anyone know what is up with my fuel gauge? the needle starts at just below full and when I turn the key on it goes way above full. I only put 10 gallons of gas in the new tank along with new electric fuel pump and sending unit from Holley.
Old October 6th, 2022 | 01:46 PM
Either you have a open in the signal wire, or no ground.
Ground the signal wire to the sending unit, turn on the ignition. The gauge should read empty. Remove the ground, the gauge should read beyond full.
if that check out, make sure the ground for the sending unit is clean and tight. If so, the sending unit is defective.
Old October 6th, 2022 | 02:04 PM
So this is NOT a factory sending unit? Do you know what the resistance rating is on that sender? Does the sender match the gauge? If you are using a stock gas gauge, it requires a 0-90 ohm sender (0 ohms EMPTY, 90 ohms FULL). Most aftermarket senders are 240 ohms empty and 33 ohms full.
Old October 7th, 2022 | 10:26 AM
Bills67's Avatar
I called Holley up and they said my sending unit should be 0 to 90 ohms! I have my ground wire connected to the frame, or should I connect the ground wire to the body where is was from factory?
Old October 7th, 2022 | 03:42 PM
The frame SHOULD be grounded, but who knows. A wire to the body wouldn't hurt and is easy to test.
Old October 8th, 2022 | 12:22 PM
Bills67's Avatar
It is grounded, I did a continuity test with my meter! thanks for reply
Old October 8th, 2022 | 02:26 PM
Bills67's Avatar
I did all the checks and my gauges stays the same! I have 10 gal. of gas in tank and the ohms on sending unit read 15.4 ohms and there is 6.4 volts on the wire coming to the sending unit from gauge. the gauge reads just below full and goes up from there when key is turned on!
Old October 8th, 2022 | 05:50 PM
Bills67's Avatar
do you know what kind of voltage should be on the wire to sending unit? mine reads 6.1 volts! and 15 ohms on the sending with 10 gallons of gas in tank.
Old October 8th, 2022 | 05:54 PM
The voltage is supposed to vary depending on the level in the tank. That's how the gauge operates. The variable resistor in the sending unit varies the voltage on the wire to the gauge. That's how all your sending units for factory gauges (oil and temp) work.
Old October 9th, 2022 | 09:14 AM
Bills67's Avatar
I did not know that. I also wanted to say that I just got done hooking up my original sending unit ( out side the tank) with ground wire to original position on body and to the wire going to dash and I still have the same issue!!
Old October 12th, 2022 | 06:51 AM
sysmg's Avatar
... with ground wire to original position on body and to the wire going to dash and I still have the same issue!!
Therefor it could be the ground wire to the original position on the body (try grounding it to a new clean spot).
Or it could be the wiring to the dash, you can temporarily run a new wire if the ground checks out OK.
Another thing you can do is use the new sending unit and connect it directly to the gauge and ground it inside the car. If it works there, then it's definitely in the wiring or the ground at the rear.
Old October 12th, 2022 | 10:38 AM
Bills67's Avatar
well I did hook the ground wire to a clean spot on the frame (checked continuity to body) and still have same issue. I guess my next check will be the wire going to the gauge, I will run a new wire from SU to gauge and see what happens! thanks for info!
Old October 12th, 2022 | 10:42 AM
sysmg's Avatar
Try doing it by the dash if you still have the sending unit out. It will confirm that it is definitely the factory wire from the dash to the SU.
Old October 12th, 2022 | 12:27 PM
Bills67's Avatar
Got it!
Old October 16th, 2022 | 03:27 PM
Bills67's Avatar
ain't I suppose to have 12v between the top two screws with metal tabs? if so, I do not!
smparr
November 6th, 2021 07:53 PM
JonnyO
August 30th, 2021 04:21 AM
69350rocket
May 11th, 2015 11:48 AM
ACID64
September 7th, 2011 11:16 AM
Sues Oldsmobile
August 18th, 2009 06:23 AM
Quick Reply: gas gauge (fuel gauge)
